06 CTT P2403, P0441, P2187, P2189 Codes
Hi,
I am new to the forum and have researched all previous threads and would like to see if someone can confirm my assessment. I recently purchased a 06 CTT with 52k. Car runs great, but shortly after purchase I receiving the random P2403 code (EVAP LDP circuit) without any other codes. I have had the entire system smoked 2 times and have had the LDP replaced; therefore, confirmed that there are no EVAP leaks and have replaced the gas cap. At one point, I went about 2 weeks without the P2403, but it started tripping randomly again. The 2403 code will only occur when the vehicle is cold and within the first couple of minutes driving, otherwise it does not trip after warming up. About a month later, I finally received a P0441 (EVAP purge flow incorrect) after the engine was warm. A few days later, I also received the P2187/P2189 (Bank 1/2 lean) codes. Now, I randomly receive the P0441 and P2187/2189 codes with the P2403 code pending. From all my research, I believe that the purge valve is failing which is tripping the P2403 and causing the lean mix on both banks. Can anyone confirm my assessment or offer any additional advice? Thanks in advance. |
Information Junky
The P0441 I've dealt with. ..I wrote up a pretty good description here https://forums.pelicanparts.com/porsche-cayenne-macan-forum/506799-incorrect-purge-flow-durametric-fault-code.html
I was amazed how much influence that little evap valve had on the running of the engine.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Thanks island911. Your post helped me troubleshoot my problem. Did you have codes other than P0441? Prior to the P0441 code, the car was running perfect, no fumes, and no problem starting (other that slight initial hesitation). Since the P0441 it idles a bit rough when cold, otherwise it still runs great. It would make sense that it is the purge valve and truly hope that valve is the issue cause this is getting really frustrating since I cannot stand driving with the CEL.
Information Junky
I had just the one fault code on that. Mine a '04 955S
Perhaps the turbos change the possibilities of what's wrong.
| Tags |
| p0441 , p2187 , p2189 , p2403 |
