Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
914-6Porsche's Avatar
Next big coolant leak for the V8's
The next big coolant leak for the S and T's will be this coolant T located between the engine and firewall. I don't have any other details other than they probably crimped the clamps to tight and weakened the T.
Old 01-07-2013, 04:44 PM
CaveVan
Send a message via AIM to Streetcrawler
This has been pretty well documented and has become part of the coolant pipe swap for most people since its a bit easier to get to with the intake off.
Old 01-10-2013, 07:56 AM
Hell Belcho
Nostril Cheese's Avatar
Dont even attempt it without removing the intake. You'll end up breaking even more plastic lines trying to replace that T fitting.
Old 01-14-2013, 06:18 PM
mikeesik's Avatar
Silly cheap easy fixes for the Manufacturer.
Not so much for the Purchaser.
Confuses me about quality on the German side.
Formerly from ratslist.
AMG E 55..2002.
Lotus Esprit SE. 1990
Old 01-22-2013, 07:56 PM
yes, mine just let go last night! I did the coolant pipe upgrade two years ago , but not this pipe. Can it be done without taking off the intake manifold, please say yes!
Mike Platt
Car issues under restoration: 1977 911 targa, 1962 356b, 1983 944.
Drivers: Mini JCW countryman, 1992 Sunburst yellow Miata, 2009 Honda Ridgeline
Old 02-06-2013, 06:47 PM
Scott R's Avatar
Not on the v8, the FSM says this as step 1:
Courtesy of PORSCHE OF NORTH AMERICA, INC.
1. Drain cooling system. --> 193817 Draining and filling coolant (includes bleeding)
2. Remove intake-air distributor. Refer to 24 46 19 Removing and installing intake-air distributor - as of
MY 2003 (Cayenne S TIP, Cayenne S MAN, Cayenne Turbo, Cayenne Turbo S, Cayenne S TIO Titan) .
INFORMATION
Component overview
Of course that section is like 20 pages.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-06-2013, 08:47 PM
arghhh! well at least i won't need to drain cooling system, as it drained itself when the hose went I'm going in this weekend! Whoo Hooo. I almost forgot how much fun it was doing the coolant pipes.
Mike Platt
Old 02-07-2013, 06:22 PM
I believe that if the pipes were changed by a Porsche dealer an entire swap was done not just a partial.....that's what my dealer told me.... Trust but verify
Old 02-08-2013, 04:12 AM
My pipes were changed by the dealer and they didn't change the T.
Old 02-08-2013, 04:41 PM
After a chat with my mechanic a bit of good news is, as the OP mentioned, the t was too crimped . With normal tightening it should be fine .
Old 02-10-2013, 05:17 AM
Hell Belcho
It isnt that bad. I can typically do it in under 5 hours including changing the starter. An air saw and poly grease help quite a bit. The biggest pain is getting the bits of plastic out of the existing aluminum fittings. PM me if you have any questions.
Old 02-12-2013, 12:08 AM
Any thoughts if I need to stick with the Porsche coolant? Its 85 miles to the dealer and if I can use some other brand it may help. Otherwise the job is moving along. Getting ready to dive into the firewall area to get that darned T out
Mike Platt
Old 02-12-2013, 04:44 PM
Scott R's Avatar
We need to get someone like LN engineering, or Elephant, or somebody clever like that to machine a steel T.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-12-2013, 05:08 PM
Hell Belcho
Or you could just go down to your local hardware store..
Old 02-12-2013, 05:10 PM
Hell Belcho
I only use the Porsche coolant.
Old 02-12-2013, 05:11 PM
The NAPA store here stated that the Zerex DEX-COOL is the stuff to use. I don't remember the cost but it is probably under $15/Gal.
Old 02-13-2013, 04:25 PM
