Looking for a 356
Just curious about pricing for the following ad. https://www.thesamba.com/vw/classifieds/detail.php?id=2198208
Just started shopping around and getting a feel for the current market. |
yikes. Someone needs some welding lessons. i'd find one that hasn't been messed with that much. To make the listed one right will cost $$$$ and will not be worth it.
You're referring to the underneath pic?
yes, the welding at the longitudinals is rather sub par. You can only wonder what else was hacked. Unless you can do most of your own welding and restoration, you're probably better off spending $15 or 20k more for a solid example than to try and resurrect a non matching T5 with tons of issues. It will end up costing you twice as much. Take your time and buy the best you can afford. they are still out there.
I'll keep looking. Not in a hurry. I don't mind a non matching numbers car. Just want it mechanically and structurally sound.
This guy may have what you're looking for or know someone that does. Good luck with the search!
https://unobtanium-inc.com/cars
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C |
But we always have lots of cars, so reach out if you have any questions about the market. ---Adam ![]() ![]()
http://www.unobtanium-inc.com 356 Registry 17369 Early 911S Registry 912 Registry, PCA |
Thread Tools | |
Rate This Thread | |
