What would this be worth?
I have a 1985 930 all steel slant nose conversion. 3.4 Kremer conversion k27 turbo ruf inter cooler and 4 outlet exhaust. Also manual turbo boost contoller. The car is guards red with black interior with stock fuchs wheels. 930s steering wheel. The interior is about 98% mint while the exterior is very nice with the stardard rock chips that a 23 yr old Porsche would have. It has 65XXX miles and clean carfax. Private message me with your opinions. Thanks in advance.
ttt
Tough call.. Seems nowadays 930s are overlooked. No longer the top of the hill in performance and without modern niceties or hp that a "new" 997 has, it will take a certain person to search one out. Given that it is an '85, it is a "euro" car, which may or may not add favor to its value. A non-factory conversion is only worth the quality exuded when the car was converted, but I don't value a non-factory conversion to be worth more than a standard, original fendered car. IIRC, for comparison, the US M471 (turbo look option) was a $12k premium when new. I am not sure a non-factory conv would return that much of a premium, for example. It certainly may have cost it though.
I guess low to mid 30's, imho.
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
Slumlord
I think racer is close, a bit high if anything. $30,000 might be the best you can do.
I don't think the slant-nose conversion helps you here. |
Also what kind of power could I expect from this conversion?
Slumlord
I am guessing 300 Hp?....
Stock for 1985 (euro) was 300hp. With the 3.4 and larger turbo, you could see 350-400.
ttt
ttt
