Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
Another Ebay 930; too good to be true?
So I was cruising Ebay and came across this ad:
http://cgi.ebay.com/ebaymotors/Cars-Trucks___Porsche-930-3-6-twinturbo-with-830hp-to-the-wheels_W0QQitemZ110286134638QQddnZCarsQ20Q26Q20Tru cksQQddiZ2282QQcmdZViewItem?hash=item110286134638& _trkparms=72%3A727%7C39%3A1%7C65%3A12%7C240%3A1318 &_trksid=p4506.c0.m245
Item Number: 110286134638
Looks like it was done nicely. Frankly, I'd love to see this car in person, and drive it. The ad states "This car started out as an original rust free930 turbo with only 15000 miles. About 10 years age the car was update to be a street or strip show car.It was striped down to the metal and redone. The car has a 3.6 custom built twin turbo engine that made 830 hp to the wheels ..."
I frankly can't understand why someone would convert a '79 930 that had so few miles on it (and being in show quality). To me that is a very significant year for the 930. A mint '79 930 would fetch much more than one that has been updated as this one has. Hey, to each his own. I bought mine heavily modified and I've continued to modify mine with performance enhancing modifications. But mine was already bastardized, the ad doesn't claim this for this car.
I'd love to do these mods to my car, but I think that I would have to spend about $30k at a minimum with used parts. Certaintly more than my car is worth.
So what do you guys think? Is this car for real? Why would someone convert a '79 930 into a '94 turbo S look-a-like when they could have done it with any other regular 911 or 964 of this time period?
I do think the pictures posted on there are pretty nice (although the door speakers cut-outs are in the RS door panels minus the speakers).
-Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 09-06-2008, 09:31 PM
Formerly reformed
Sideways Tach. I must have this car!
1968 911P (Paperweight)
Old 09-06-2008, 09:38 PM
Wow.... those mods look gooood..... I prefer the old 930 body style though.
Old 09-06-2008, 10:25 PM
K9Torro's Avatar
The wording in that listing would give me pause, it could simply be that English is not the persons first language but alot of the scam add's are written as poorly in the snytax and grammar department.
Todd
Old 09-07-2008, 02:10 AM
ZAMIRZ's Avatar
They even grafted in the 964's raised center tunnel, that is some serious work.
Amir
'83 911SC
Old 09-07-2008, 02:46 AM
I will admit, the induction, exhaust, and turbo arrangement is awesome except for the lack of heat. If someone made that in kit form I might have to try and decide just how important heat is to me.
1989 Carrera 3.2L in 993 bodywork
Old 09-07-2008, 08:36 AM
Which is why it's cheaper than some would expect, along with the MOTEC.
That car has some serious work in it, it's just the cosmetic stuff that turns people off. Hopefully someone changes it back.
'84 911, some sort of red color
'05 Subaru WRX wagon
Old 09-07-2008, 09:44 AM
3.2 CAB's Avatar
That is up in Ronnie's(RoninLB) neck of the woods. Maybe he would look at it for you.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 09-07-2008, 10:05 AM
Soldier of Fortune
DasBoot's Avatar
Originally Posted by richde View Post
Which is why it's cheaper than some would expect...
Where is it cheap?
Old 09-07-2008, 12:40 PM
Jim Smolka's Avatar
One safety item of worth mentioning. Look at how the seat belts are run. With that downward angle, the belts would compress a persons spine in a wreck!
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 09-07-2008, 12:54 PM
MattAlpha's Avatar
My basic question is why would someone modify a '79 930 to begin with?
I can't imagine doing this to the car the auction claimed it was.
Since some much was changed/modified, why not do it to a Carrera or a 964 Coupe roller?
Old 09-07-2008, 01:40 PM
Crotchety Old Bastard
RarlyL8's Avatar
I've seen that car before. Love it. One thing puzzling is the angle on the waste gate's inlet tubing. It appears to be angled backwards of exhaust flow.
Old 09-07-2008, 03:11 PM
That looks like an unlimited budget build with over $50k in mods alone. If I knew I was going to do such a car and had that kind of money to spend, I would want to start w the best donor I could.
If you are truly interested in the car and that is your concern, just make sure you get the VIN and run a CARFAX on top of other reasonable due diligence.
I thought eBay always had the vin numbers in their adds. Has that changed as I did not see one here?
Bet he dose not let it go for under $50k.
Old 09-07-2008, 05:46 PM
Drivin' Miss Daisy
benzyne's Avatar
A '79 won't be in the CARFAX database. It was before the automakers went to a standardized 17 character VIN.
58 VW Split Window Bus - Porsche Powered
78 911SC Turbo Look - Megasquirt II, EDIS, 964 intake
92 964 Turbo
Old 09-07-2008, 07:59 PM
Some people attempt to get around this common sense rule by using a seat that has been tested to be able to take the loads imposed on them by the poor belt routing. The manufacturers of the harnesses have a list of acceptable seats. I think it's a big mistake.
What's worse is that the shoulder belts appear to be attached at a point that isn't structurally sound enough and there looks to be a sub belt laying in the passenger floor, which leadds me to believe that those have been installed improperly as well.
I don't understand how people can screw this up time after time. The information is out there, and it's free.
JR
Old 09-08-2008, 05:40 AM
MattAlpha's Avatar
Thanks guys. I'd love to buy the car, but I back on a ship again. No time to drive for pleasure until we move the mine sweepers to San Diego in the Spring. Once that happens I'll figure a way to get my 911 out there. Probably will be another road trip.
Old 09-08-2008, 07:59 PM
