Glovebox won'''''''''''''''''t open
I have a 1988 bmw 325IX and I can't get the glovebox open.. It isn't locked. The handle lifts up but, the door doesn't open!! Anyone know what to do?
Old 02-10-2007, 05:06 PM
BMW Roundel
Take it loose from the back & rock it loose
Old 02-15-2007, 05:46 PM
I have taken the three nuts off that hold the rear hinge in place But, I still can't get it open.. I have tried to shake and twist the whole glovebox and still nothing. I ws able to get my arm up behind the box and reach inside and nothing is binding.. Even if I had to force something and have to order a new part, I don't know what to do!
Terry
Old 02-15-2007, 06:02 PM
I'm going by the shop tonight and I'll look at the one we have out back and get an idea about how to get it open.
1993 318i manual
Old 02-16-2007, 12:50 AM
Try prying down the glovebox right near the hinge a little bit. You should be able to see the 2 philips head screws that hold the latches hook. Just unscrew them and it should just fall right out.
1993 318i manual
Old 02-16-2007, 09:35 PM
I now have the two philips out that are at the center behind the door. I tried to pull down on the door but, the door doesn't drop down far enough to unlatch.
Terry
Old 02-17-2007, 07:34 AM
If its NOT locked it should just pull down~~>really hard..have done many that way & have never had a problem
Old 02-18-2007, 01:00 PM
Do I pull down on the handle or the door itself after the two screws are removed?
Old 02-18-2007, 01:12 PM
On the door
1993 318i manual
Old 02-18-2007, 05:10 PM
