gerry (guest)
Guest
Posts: n/a
i have a 1992 bmw 325i,how many 02 sensor does t have ,coz ive been having eratic idling cold start and ive already replaced icv,map but still having the same problem..need sos advice pls
This post was auto-generated based upon a question asked on our tech article page here:
Old 09-06-2013, 12:11 PM
Nick at Pelican Parts's Avatar
There should only be one before the cat. Cold starting problems could be related to a vacuum leak, inspect the engine for a cracked intake boot, vacuum line or leaking gasket. You can also check the crankcase vacuum, this will help you diagnose the crankcase breather valve.
- Nick
