Turbofrog
smurfbus's Avatar
Update. Another near flat bed mayhem on two hour drive. After that back to basics as now the pedal stick to floor. So the omega was misaligned but after all was in spec adjusting wise the cable still felt loose and was not broken so maybe the clutch pedal pin was broken and IT WAS! I had replaced it with pelican copper kit 5 yrs ago so I did not even check it before. Now I replaced it with a bolt and nut and clutch is fine again.
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 08-18-2019, 08:54 AM
A google search for Sachs 3032047099 turned up this thread and I hope you guys can help.
I just bought a new/unused pressure plate that was allegedly for my 1986 930, but it is aluminum and clearly of different dimensions than my old one. Can anyone identify this pressure plate, and before I return it, let me know if there’s any way to use it in my car. Perhaps some sort of spacer, adapter, or a longer throw out bearing?
Thanks guys
Ken
Ken
1986 930 2016 R1200RS
Old 04-26-2020, 03:39 PM
Is that the lightweight pressure plate? Requires a throwout bearing adapter. TK has one.
https://parts.turbokraft.com/collections/911/products/930-lightweight-clutch-adapter-kit-1
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 04-26-2020, 04:08 PM
I believe you’re correct. I found a part number 88 3082 999 594 in white lettering on it... and its an 11.5lb lightweight pressure plate for 930s. It’s a lofty $1,100 from our host. I don’t want to spend another $420 to fit it o my car, though, so I’ll be trying to return it to the private seller.
https://www.pelicanparts.com/More_Info/883082999594.htm?pn=88-3082-999-594-M410
Ken
Old 04-26-2020, 04:28 PM
Porsche 935's Avatar
Be careful, I went through the same thing. The 934 disc is only like 6mm thick. The standard one is 8.5mm. Talk to patrick ms, they can direct you and have most in stock.
3.3 ltr, stock compression, efi, twin turbo - no intercooler.
Old 04-27-2020, 06:50 AM
Scottsdale Arizona USA
Day @ Euro Parts West, LLC, Scottsdale, AZ USA // Automotive Part Connectors & EPW MODE : Motorsport Design
+1 (844) URO-PART // modepw@europartswest.com
Old 04-28-2020, 11:13 AM
Old 07-24-2020, 02:03 AM
Old 08-29-2020, 03:53 AM
