I didn’t bother with a knock sensor since I figured a loud 930 engine would interfere with it but since I didn’t install one I don’t know if that’s true or not. I did go sequential since I’m running big injectors and wanted a good idle. I put a screw in magnet on the oil pump spacer that replaced the air pump gear and a sensor on the housing.
Maybe we should have thread just for e-throttle if there’s not one already. I’d like to go with it because I can’t get my 930 to Carrera TB linkage to be as smooth as I’d like. There’s still a little sticking right off idle and I’ve tried a few different bell crank ratios.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Check out the link that dap930 posted. Looks pretty promising
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
Stranger on the Internet
Crank sensors, especially if you are going to mount them on the flywheel.
Knock sensors. Throttle position switches if necessary. Vacuum and manifold ports as necessary. Various temperature sensors (depends on which EFI you're going with).
Patrick E. Keefe 78 SC |
definitely want to do sequential.
not sure of injector size but figured around 80#. ports have been opened up to 38mm and I have an SC cam and twin plug. 7200 turbo that has been modded for reduced lag. B&B type header RUF IC where are you mounting the MAP sensor. I pulled out the "Y" pipe but have not plugged the hole yet, also have a hole in the back side of the manifold I have to plug that is threaded. what are the benefits of the different RPM sensors. pulley on the front or flywheel. so I need cam sensor flywheel or pulley sensor MAP- where to mount throttle position SW CHT IAT sensor- where to mount pics would be great if anyone has them. yes I am still searching threads and reading, but there are so many different ways people are doing things.
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
MAP sensor has to be under the throttle plate - otherwise it can't read vacuum, just like the boost gauge can't. Other than that, it can be pretty much anywhere. Mine is tee'd off a port on the throttle body.
IAT isn't incredibly useful in my experience, other than showing heat soak if you let the car idle or shut it off and start it again. It'll just read ambient within a couple of minutes of moving off. Mine is in the outlet neck of the intercooler; a port in the inlet manifold itself would likely work just as well. Front-mounted pulley sensor is more convenient to get at/gap with the motor in the car - especially if you don't already have a factory EFI flywheel with the missing teeth and/or the notches in the transmisson for the sensors. And the bracket(s) etc.. Some say the flywheel is a better source (bigger teeth/stronger signal). I use a Bosch sensor (with Clewett's belt conversion) anyway, and it seems fine.
'77 S with '78 930 power and a few other things. |
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC '12 Gallardo LP-570-4 Performante Ducati 748R |
I'll add a few pics to the discussion:
Ingenieur
I think Spuggy was thinking of AmbT, which is not critical for normal use.
A few more pics of my mess of an engine:
Kokelyn; I do like 'em and it does seem to work pretty well, but I hadn't thought it was that exceptional.
Here's a log from a 30 minute drive, after the car sat baking in the sun (August, so probably 90F, at least) for several hours: ![]() Quote:
Huh. I know heat soak is an issue on the dyno; even with box fans/bags of ice etc. But this is leisure driving - don't even reach spring rating, much less get the wastegate open. The only time my IAT is the same as the ECU temp (in the engine bay) is before I start driving; see how it drops @ the 3-4 minute mark - when I use some RPM. CHT and oil (chaincase) temps climb when I stop and idle. But IAT and ECU temps don't seem to be very affected, as long as the fan is turning. I see pretty much the same even in colder weather. IAT may rise a little with longer periods of boost - but this is a far cry from a dyno run, and it recovers very quickly at anything over 35 MPH. If I stop for some reason and switch off, restarting within 5-10 minutes, IAT will spike considerably (20? 30C?) higher than the "moving" readings. And go back down within a few minutes of moving again, even on city streets.
got my MS3 EVO yesterday
I am using the stock 930 intake
Glad it made it ok. I would call up chris at turbokraft and he can get you set up with a lot of the adapter parts that will make your conversion much simpler.
david,
what cam sensor did you use. does it have to be put in in a certain location as in TDC
Could I machine a hole here for the CLT
Why not put it in the breather cover plate? There's probably a hole or a boss there for something else that is likely unused now. If not, its easy to do, new breather covers are cheaply available, and you don't run the chance of screwing up something expensive.
just remote the plate and do you drilling/tapping on the bench not on the engine lol
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
Hopefully someone with more experience can chime in.
If crank ref is noisy - eg a mag sensor - actually getting sync can take more revolutions - due to bogus signals confusing the issue; helps a lot to establish how much voltage you're getting at cranking RPM (a product of the air gap setting for a mag sensor) and set the noise floor to ~60% of cranking voltage, so that any noise is ignored. At idle, I see over 30V peak-to-peak (ie >15V above the zero axis) - but when cranking at 200 RPM or so, only ~2.2V peak-to-peak. Setting noise floor to 0.6V made starting a lot faster on the key - at a lower setting, it was clearly spinning over a few more times to get sync before trying to start.
Scottsdale Arizona USA
^ Top upper left complements of Chris at TurboKraft for the air pump housing cam sync sensor.. 1/2 speed pickup for sequential fuel injection. ![]()
Day @ Euro Parts West, LLC, Scottsdale, AZ USA // Automotive Part Connectors & EPW MODE : Motorsport Design +1 (844) URO-PART // mode@europartswest.com |
Thread Tools | |
Rate This Thread | |
