Brando
quattrorunner's Avatar
I did search..But why not a 996 trans again?
I'd love a g-50 but the Porsche tax guys are massive I guess. Why not a 996 6 speed in my g-body? I'm willing to mod things like torsion tubes and mounts.....
Will it not bolt up? Is there no compatibility with flywheel and clutches?
Turbo powa!
1977 911s. it's cool
Old 02-08-2024, 09:39 AM
gearhead
A 996 Carrera gearbox? Starter is on the wrong side. They are engine mounted on M96 water cooled cars.
A 996 GT3 or Cup Car gearbox would be fine.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 02-08-2024, 10:09 AM
David's Avatar
I thought someone did this recently but I could not find the story when I just looked.
It was not an easy task though. If I recall, they were planning a kit but there was a significant cost for it before even buying the tranny.
Old 02-08-2024, 11:00 AM
7.0:1 > 11.3:1 > 7.0:1
No longer impossible! 996/997 transmission onto air cooled engines!
Old 02-08-2024, 11:41 AM
Chain fence eating turbo
My only reservation is the sealed bearing on the pinion.
Old 02-08-2024, 06:17 PM
gearhead
If the gearbox is updated and serviced, it's not really something to worry about.
The downsides of the box are that you cannot change the gear ratios on it and it's a single rebuild design. The interference press fit of the gears only takes one rebuild and then they get too loose to be reliable. You need all new gears on the second service of it.
1974 914 Bumble Bee
2009 Outback XT
Old 02-09-2024, 07:16 AM
Mike Billings's Avatar
What's the downside of 996 turbo trans?
axles, cost, length, weight, ratios, shifter, speedo, hydraulic clutch release
Is there anything I'm forgetting? Expect trouble with the ring gear?
07 911 Turbo - Pilot Sport Cup 2 ZP
96 Carrera 4 - Toyo R888r
73 911E - Hoosier R7 + twin 75's
92 Corvette - Nitto NT01
14 BMW X3 - Pilot Sport A/S 4
Old 02-11-2024, 09:25 AM
Brando
Just 996 not turbo trans if they're different.
Turbo powa!
Old 02-13-2024, 06:25 AM
