Brando
I did search..But why not a 996 trans again?
I'd love a g-50 but the Porsche tax guys are massive I guess. Why not a 996 6 speed in my g-body? I'm willing to mod things like torsion tubes and mounts.....
Will it not bolt up? Is there no compatibility with flywheel and clutches? Thanks
Turbo powa! 1977 911s. it's cool |
gearhead
A 996 Carrera gearbox? Starter is on the wrong side. They are engine mounted on M96 water cooled cars.
A 996 GT3 or Cup Car gearbox would be fine.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
I thought someone did this recently but I could not find the story when I just looked.
It was not an easy task though. If I recall, they were planning a kit but there was a significant cost for it before even buying the tranny.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
7.0:1 > 11.3:1 > 7.0:1
Chain fence eating turbo
My only reservation is the sealed bearing on the pinion.
gearhead
If the gearbox is updated and serviced, it's not really something to worry about.
The downsides of the box are that you cannot change the gear ratios on it and it's a single rebuild design. The interference press fit of the gears only takes one rebuild and then they get too loose to be reliable. You need all new gears on the second service of it.
What's the downside of 996 turbo trans?
axles, cost, length, weight, ratios, shifter, speedo, hydraulic clutch release Is there anything I'm forgetting? Expect trouble with the ring gear?
07 911 Turbo - Pilot Sport Cup 2 ZP 96 Carrera 4 - Toyo R888r 73 911E - Hoosier R7 + twin 75's 92 Corvette - Nitto NT01 14 BMW X3 - Pilot Sport A/S 4 Last edited by Mike Billings; 02-11-2024 at 09:30 AM.. |
Brando
Just 996 not turbo trans if they're different.
