Crotchety Old Bastard
The client was wanting an RSR look with the turbo power plant; a rather unusual combination. I came up with this idea to fulfill the vision. To keep with the theme I purchased a set of RSR racing megaphones and cut the ends off to use with my system.
So no, I did not make the tips.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Finally i have got my crank, clutch, rods, flywheel and pistons weight adjusted and balanced. The weight difference between each rod with piston is now 0,1 gram.
the lightweight pressure plate is also balanced. I also received my 3.2 carrera cylinder heads back from the workshop last week they have been surface-grind and valves leak tested. I desided to use the original rod's and the original 930 oil pump. Here from pelican parts i have received raceware rod bolts and supertec cylinder head stud kit. So now i'm quite ready to start assemble the engine. ![]() ![]() ![]() My new 964 turbo cylinders ![]()
911 Project |
Already done it.. works nn-iiiice
A bunch of old race cars |
Rod's are ready and mounted on the crank.
![]() ![]() The 3.2 carrera cyllinder heads ![]() ![]()
911 Project |
Camshaft
The Carrera 3.2 camshaft (for left side) that have been extended so the original oil return pump from turbo can be used.
911 Project |
Now i will soon start programing my Haltech EMS system, does anyone know if it's possible to download a setup that fit's some way a 930 engine?
I'm most worried about the ignition curves.. ![]() ![]() ![]() ![]()
911 Project |
I use the Haltech E11v2 and would be happy to share my file as a starting point.
I'm not sure it works on your E6 so you'd need to check. Otherwise I can talk/email you through some basic settings enough to likely get you going. It's looking good!
Glenn 87' 930TT |
Please e-mail it to me and i will check it, it is probably the same software? stav1973@hotmail.com
911 Project |
Test mounting the engine without the gear box, to do intercooler preparation.
911 Project |
user & abuser
wow the water intercooler can be alot smaller... doesn't look like the same cooling power, but we all know it will likely exceed what an air-to-air can do!!!
keep us updated!
vini vidi vici |
Agree it's oversized ![]() So if i run air-condition, it's possible that the temperature can rise up to 55°C ( 131°F) and then it's good to oversize the intercooler. /Kjell Robert
911 Project |
Powerpack
911 Project |
Very clean and impressive install. What, if anything, have you done to your 915 tranny to handle the extra power?
'79 930/934 replica 80 RSR-look(Now in Sicily) 914/6 2.7 (Projekt 908/3) 1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW D-Zug Produkte/D-Zug.com |
It's a 930 4 speed tranny, with a lightweight cluch that can handle 650hp
911 Project |
Any news??
Any updates? What clutch did you end up going with?
Just keep the rpm's under about 6500 and the rods should handle all you can through at them.
I believe a modulated system that would spray a mist of say, distilled water over the intercooler would be much simpler that a watercooled intercooler system running both lengths of the car. The windshield reservior could substitue as a tank for the water, and run lines to the back of the car. Just a thought...
Max Sluiter
That would only be suitable for drag racing or street duty without sustained boost usage. A track day would burn through the water supply right quick and then you would have to shut off. If you tune the motor not to need the water, you are leaving power on the table that could be gotten by fitting an air-to-air intercooler which never runs out of coolant.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Wer bremst verliert
This is an old post...I did some similar thinking and went with a big Bell air-air intercooler with a pair of shrouded radiator puller-fans. No water weight or complexity, keeps intake temps at most 20 degrees over ambient.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy Last edited by JohnJL; 05-24-2010 at 04:57 AM.. |
