Anyone running Zeitronix?
Anyone out there running Zeitronix on there 911/930? I like the fact that the ZT-2 can monitoring Air/Fuel ratio, Boost, EGT, RPM datalogging up to 9 hours of data..
Also curious to see if anyone has mounted the LCD display in a 911 and where it was put.
Some of my friends with riced STI's and Balls out Supra's swear by zeitronix and have no complaints other than the boost sensor costing $100.
When comparing both systems I am leaning more towards Zietronix and with being able to display 4 outputs this scores pretty high for me but I know from reading this form that LM-1 wins the popularity contest.
If anyone has expierence with the Zeitronix in a 911 please post your comments.
Zeitronix ($399 with display):
http://www.zeitronix.com/Products/zt2/zt2.htm
LM-1 ($349+plus $589 for the Aux Box ):
http://www.innovatemotorsports.com/lm1.php
Old 10-27-2007, 01:24 AM
We are running the Zt-2 on several turbo/supercharged cars
and I like them a lot, quality and support is great.
I want to put one in my 930, but still the exhaust is not ready.
The display I plan to put on top of center console.
One big advantage of the ZT-2 is a programmable relay trigger
and alarm beeper.
For example at 4000rpm and 0,4 bar a relay can be switched.
A boost solenoid can be switched with this.
Or above 5000rpm and above 14 AFR alarm will beep or flash.
Falk
87 930 bblk/blk
88 3.6 white/blk
Old 10-27-2007, 09:06 AM
I've been running one for about 2 years now, and really like it. The readout fits nicely in the stock ashtray opening.
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 10-27-2007, 10:20 AM
Send a message via AIM to Ag02M5
Originally Posted by Falk930 View Post
One big advantage of the ZT-2 is a programmable relay trigger and alarm beeper. For example at 4000rpm and 0,4 bar a relay can be switched. A boost solenoid can be switched with this.
I am planning on doing precisely this...in addition, I will be logging: rpm, boost, afr, and fuel pressure.
Coupled with a Brian Leask WUR...I think I will be pretty well tuned.
I don't know exactly what Zeitronix has lined up but I asked them about a round gauge (that might fit in the clock area) and they told me wait until SEMA.
So next week I should know where I want to take it.
I was looking at Innovate but after reading their forums, I wasn't impressed. They have a product that claims to have the configurable triggers (multiple) but the actual product doesn't support the features advertised/in the manual. No time frame as to when they will either.
No first hand experience though.
WTB: 964/965 Turbo stuff...carbon fibre bits, Techart wheel parts, RS/lightweight flywheel, 993 EVO uprights, G50 gears or 6 sp., 964 RSR swaybars, custom droplinks and any other cool stuff, pm me! Also a nice medium build 327 Chevy engine.
Coming SOME DAY...1991 3.3 turbo, Tahoe Blue Metallic with some mods
Old 10-27-2007, 04:47 PM
Problem I see with the round gauge is that it will only disply Air/Fuel which is the same for Innovate but if you use the LCD you can display 4 parameters all together and from what my friends have told me the boost is very acurate.
Falk/Winrice, can you guys take some pictures on where you have the LCD? I have a 993 lower dash so I am not sure if the size's are the same
Old 10-27-2007, 07:24 PM
My taste for the 930 is more the LCD display, the ZR-1 is to modern maybe.
The new ZR-1 round gauge is available, we have tested it here and are impressed.
But wait for SEMA, there will be good news!
ZR-1:
Falk
87 930 bblk/blk
88 3.6 white/blk
Old 10-28-2007, 12:55 AM
Here you go!
1986 911 Turbo
Old 10-28-2007, 01:07 PM
Thanks Winrice, I will need to check my 993 lower dash and see if it will fit there. Did you purchase another MAP sensor to measure the boost or did you tap into the stock on?
Old 10-29-2007, 04:01 AM
I'm using the Zeitronix MAP and EGT sensors so I can have independent systems.
Even when I go EFI I'll still keep all the Zeitronix equipment separate, just to have a redundant logging system.
1986 911 Turbo
Old 10-29-2007, 09:03 AM
and alarm beeper.
Falk
"For example at 4000rpm and 0,4 bar a relay can be switched" mmmmmm this has me now thinking of additional injector controller another +1 for Zeitronix
Old 10-29-2007, 08:51 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
So give us a hint about SEMA !!!
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 10-29-2007, 09:26 PM
Yea I was thinking the same thing, I was just under the impression that the ZR-1 would be the newest and greatest thing from Zeitronix. If there is more than this than I should hold off on my upcoming purchase
Old 10-30-2007, 12:06 AM
Just for your info, the ZT-2 displays measurements:
5x2x1 inches.
Falk
87 930 bblk/blk
88 3.6 white/blk
Old 11-02-2007, 01:14 AM
As Sema is over, I can tell that Zeitronix
released the new ZR-2 display.
Its a round display like the above, but you can display
for example AFR on the outer LEDs and either
boost/EGT/AFR/TPS/ or a user def. input with the digits.
I try to get a picture and more details about the function.
Falk
87 930 bblk/blk
88 3.6 white/blk
Old 11-04-2007, 02:31 PM
Falk
Any idea of size...ie will it fit in the clock position in our cars. That would .
RT
Old 11-04-2007, 04:22 PM
Falk
Now that would be worth waiting for hopefully with a reasonable price..
Old 11-04-2007, 10:40 PM
Its a "small" gauge, 52mm.
You will need a spacer to make it fit
in the clock position.
Falk
87 930 bblk/blk
88 3.6 white/blk
Old 11-04-2007, 10:51 PM
ZR-2 $139
Zt-2 + ZR-2 $399
ZAVT-1 $69
MAP 3.5 BAR $109
52mm is correct.
And here is a pic.
Old 11-05-2007, 07:18 AM
Not bad, but curious on how you switch between different modes. I do not see any buttons or switchs on the bezel or face of the guage..
Old 11-06-2007, 09:59 PM
I'm thinking that gauge may be a bit too busy for the austere Porsche interior.
Other than boost, I doubt I would be checking them regularly. Just some tuning runs logged and then an occasional checkup.
I sure would like a pillar mounted gague pod. Why can't someone make one?!?!?!?!?
Old 11-07-2007, 11:14 AM
