Anyone running Zeitronix?
Anyone out there running Zeitronix on there 911/930? I like the fact that the ZT-2 can monitoring Air/Fuel ratio, Boost, EGT, RPM datalogging up to 9 hours of data..
Also curious to see if anyone has mounted the LCD display in a 911 and where it was put. Some of my friends with riced STI's and Balls out Supra's swear by zeitronix and have no complaints other than the boost sensor costing $100. When comparing both systems I am leaning more towards Zietronix and with being able to display 4 outputs this scores pretty high for me but I know from reading this form that LM-1 wins the popularity contest. If anyone has expierence with the Zeitronix in a 911 please post your comments. Zeitronix ($399 with display): http://www.zeitronix.com/Products/zt2/zt2.htm LM-1 ($349+plus $589 for the Aux Box ): http://www.innovatemotorsports.com/lm1.php |
We are running the Zt-2 on several turbo/supercharged cars
and I like them a lot, quality and support is great. I want to put one in my 930, but still the exhaust is not ready. The display I plan to put on top of center console. One big advantage of the ZT-2 is a programmable relay trigger and alarm beeper. For example at 4000rpm and 0,4 bar a relay can be switched. A boost solenoid can be switched with this. Or above 5000rpm and above 14 AFR alarm will beep or flash. Falk
87 930 bblk/blk 88 3.6 white/blk |
I've been running one for about 2 years now, and really like it. The readout fits nicely in the stock ashtray opening.
1986 911 Turbo 3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts. |
Coupled with a Brian Leask WUR...I think I will be pretty well tuned. I don't know exactly what Zeitronix has lined up but I asked them about a round gauge (that might fit in the clock area) and they told me wait until SEMA. ![]() So next week I should know where I want to take it. I was looking at Innovate but after reading their forums, I wasn't impressed. They have a product that claims to have the configurable triggers (multiple) but the actual product doesn't support the features advertised/in the manual. No time frame as to when they will either. No first hand experience though.
WTB: 964/965 Turbo stuff...carbon fibre bits, Techart wheel parts, RS/lightweight flywheel, 993 EVO uprights, G50 gears or 6 sp., 964 RSR swaybars, custom droplinks and any other cool stuff, pm me! Also a nice medium build 327 Chevy engine. Coming SOME DAY...1991 3.3 turbo, Tahoe Blue Metallic with some mods
Problem I see with the round gauge is that it will only disply Air/Fuel which is the same for Innovate but if you use the LCD you can display 4 parameters all together and from what my friends have told me the boost is very acurate.
Falk/Winrice, can you guys take some pictures on where you have the LCD? I have a 993 lower dash so I am not sure if the size's are the same |
The new ZR-1 round gauge is available, we have tested it here and are impressed. But wait for SEMA, there will be good news! ZR-1: ![]() Falk
87 930 bblk/blk 88 3.6 white/blk Last edited by Falk930; 10-28-2007 at 12:57 AM.. |
Thanks Winrice, I will need to check my 993 lower dash and see if it will fit there. Did you purchase another MAP sensor to measure the boost or did you tap into the stock on?
Even when I go EFI I'll still keep all the Zeitronix equipment separate, just to have a redundant logging system.
another +1 for Zeitronix
But wait for SEMA, there will be good news! So give us a hint about SEMA !!!
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
Yea I was thinking the same thing, I was just under the impression that the ZR-1 would be the newest and greatest thing from Zeitronix. If there is more than this than I should hold off on my upcoming purchase
Just for your info, the ZT-2 displays measurements:
5x2x1 inches. Falk
As Sema is over, I can tell that Zeitronix
released the new ZR-2 display. Its a round display like the above, but you can display for example AFR on the outer LEDs and either boost/EGT/AFR/TPS/ or a user def. input with the digits. I try to get a picture and more details about the function. Falk
.RT
hopefully with a reasonable price..
Its a "small" gauge, 52mm.
You will need a spacer to make it fit in the clock position. Falk
ZR-2 $139
Zt-2 + ZR-2 $399 ZAVT-1 $69 MAP 3.5 BAR $109 52mm is correct. And here is a pic.
Not bad, but curious on how you switch between different modes. I do not see any buttons or switchs on the bezel or face of the guage..
I'm thinking that gauge may be a bit too busy for the austere Porsche interior.
Other than boost, I doubt I would be checking them regularly. Just some tuning runs logged and then an occasional checkup. I sure would like a pillar mounted gague pod. Why can't someone make one?!?!?!?!?
