Badly running 930 1983 turbo
Guys , a little help needed
After being laid up for 3 months , car is running badly
1. running rich
2. will not pull past 2 to 3 thosand rev's under load , but will rev when there is no load
If you push accelerator just loses power slowly
Can anyone point me in the right direction and things to start checking in logical order ( seems that if i send to workshop - just seem to spend vast amount of cash !!!)
Also gearchange is very loose , assume that needs rebushing - any recommendations
Old 11-12-2007, 12:45 AM
9dreizig's Avatar
Send a message via AIM to 9dreizig
1) spark
2) A/F
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 11-12-2007, 08:25 AM
David's Avatar
3) intake restriction
4) exhaust restriction (do you still have a cat?)
Old 11-12-2007, 12:26 PM
930gt-40r's Avatar
WUR ruled out?
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 11-12-2007, 03:55 PM
David's Avatar
6) fuel pump
Old 11-12-2007, 04:44 PM
9dreizig's Avatar
Originally Posted by 125shifter View Post
6) fuel pump
while running rich ?? Help me on the logic of that ....seems counterintuitive
"Todd"
Old 11-12-2007, 04:47 PM
Wo ist die Rennstrecke?
DonE's Avatar
Check fuel pressure at the WUR. It regulates the amount of fuel to the injectors and for whatever the reason, its dumping too much.
Old 11-12-2007, 04:55 PM
David's Avatar
You got me there, I was just trying keep the number thing going .
It does sound like the WUR the way it's rich and won't rev.
Old 11-12-2007, 05:12 PM
Crotchety Old Bastard
RarlyL8's Avatar
I assume it was running well before it sat for 3 months.
CIS does not like to sit. The fuel head piston may be hanging up.
I would start by cleaning the entire fuel system and get rid of the old gasoline.
After that check your pressures.
If fuel system is good move to spark.
If spark is good look for mechanical or physical issues.
Old 11-12-2007, 07:03 PM
Thanks , will start working thru the recommendation on the fueling
Thanks Guys , appreciate the pointers , I will start working thru the options ,
Cheers Dave
Old 11-14-2007, 11:46 AM
9dreizig's Avatar
Texans, gotta watch you guys all the time LOL
"Todd"
Old 11-14-2007, 03:33 PM
Rory Mckenna's Avatar
WHat is the best way to clean a fuel system?
Old 11-14-2007, 04:26 PM
