Badly running 930 1983 turbo
Guys , a little help needed
After being laid up for 3 months , car is running badly 1. running rich 2. will not pull past 2 to 3 thosand rev's under load , but will rev when there is no load If you push accelerator just loses power slowly Can anyone point me in the right direction and things to start checking in logical order ( seems that if i send to workshop - just seem to spend vast amount of cash !!!) Also gearchange is very loose , assume that needs rebushing - any recommendations |
1) spark
2) A/F
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
3) intake restriction
4) exhaust restriction (do you still have a cat?)
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
WUR ruled out?
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
6) fuel pump
while running rich ?? Help me on the logic of that ....seems counterintuitive
Wo ist die Rennstrecke?
Check fuel pressure at the WUR. It regulates the amount of fuel to the injectors and for whatever the reason, its dumping too much.
.It does sound like the WUR the way it's rich and won't rev.
Crotchety Old Bastard
CIS does not like to sit. The fuel head piston may be hanging up. I would start by cleaning the entire fuel system and get rid of the old gasoline. After that check your pressures. If fuel system is good move to spark. If spark is good look for mechanical or physical issues.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 Last edited by RarlyL8; 11-12-2007 at 06:07 PM.. |
Thanks , will start working thru the recommendation on the fueling
Thanks Guys , appreciate the pointers , I will start working thru the options ,
Cheers Dave |
WHat is the best way to clean a fuel system?
