testing for faulty injector
Im still trying to find the cause of my miss and hesitation. I've changed all ignition hardware wires included. To see if I have a bad injector, I purchased a laser thermometer and tested the heat coming off each header pipe. I found the # 1 to read about 100 degs higher than the others. The fluctuation is greater too. Could this be the bad injector? Has anyone else perform this test with successs? Thanks!
79 Euro 930
Old 12-13-2007, 03:34 PM
Me like track days
Craig 930 RS's Avatar
Why screw around? Send them to:
www.witchhunter.com
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 12-13-2007, 03:35 PM
Wo ist die Rennstrecke?
DonE's Avatar
I tested mine exactly how you are describing. I sent all 6 to Marren Fuel Injection to trade them for 6 matched injectors. The temps between the cylinders closed up to 25 degrees difference at idle.
Old 12-13-2007, 03:53 PM
930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
how much for exchanged injectors?
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 12-13-2007, 06:02 PM
Owned 2 3.3 turbos and both had shot injectors,,new set costs around £200-£250 gbp here in the uk,,which is around $400-$500 dollars,,personally with my experiences i would go ahead in replace them if you have the spare cash ,,then you know you have all brand new parts in there..if not defo remove them and check/clean!
Old 12-14-2007, 06:40 AM
I agree Stup! Thats what I will do. I changed 2 and no change. I guess I may have more than one thats bad.
This has been frustrating. I was hoping to find the one but to no avail.
79 Euro 930
Old 12-14-2007, 04:31 PM
