-   -   Top End Rebuild and Turbo Project underway (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/395869-top-end-rebuild-turbo-project-underway.html)
polizei 09-16-2008 09:35 AM
I think I found the issue last night. The plumbing leading to the air filter in the engine compartment was so tight up against the #1 upper spark plug that it kept pulling the plug wire out. I tore out all of that plumbing and ran the filter in the rear wheel well. Took her out for a drive and WHAT A DIFFERENCE! It seriously HAULS! I was kind of nervous to explore the power last night since I'm still in the break-in period with the car and the fuel is still not dialed in correclty (got an LM-2 to replace my faulty LM-1), but I could definitely tell there was there was a huge difference.
After having blown off the rubber elbow connecting the AFM to the throttle body several times this past weekend, we decided to use rivets to secure the elbow to the AFM collar. It seemed to work well for a while, but it blew it off again and this time tearing through the rubber. Unless you guys have a suggestion, I'm planning to get one custom made as there needs to be a vacuum connection going to the Venturi Tube (brake booster) and for idle.
Ben, I took a picture of the boost gauge connection to the brake booster, but I forgot my camera card reader today. I'll get it up here tonight.
Thanks everyone for your help! This has been such an enormous and enjoyable learning experience for me. I would have NEVER attempted this without your advice, direction, and support. You guys seriously rock. If any of you find yourselves in southeast PA, look me up and I'll let you take my car for a spin. Thank you!
WERK I 09-16-2008 10:35 AM
That's excellent! You must feel a tremendous amount of accomplishment.
hobieboy 09-16-2008 11:11 AM
Andy, you can get a tight radius 90 deg aluminum elbow then use 2 silicone couplers to secure them. Is the AFM "hanging" there or is there a support to secure it? That may be part of the problem?
BTW - congrats on sorting out the major issues :)
jbrinkley 09-16-2008 11:19 AM
that's good to hear. congratulations
EPorsche 09-16-2008 01:28 PM
Could you do a write up (summary) of parts (in a list) and pics so others (like me) could have a good platform to start from instead of reinventing the wheel.
911st 09-16-2008 02:54 PM
What about making it a suck through instead of a blow through? This will be a better soulition if you decide to run at higher boost levels when you get your intercooler. Then you will not have to worry about blowing up the AFM.
polizei 09-17-2008 04:02 AM
Thank you all for your kind words.
The trouble is that I would need to plumb some connections off of the elbow for the ICV and brake booster - I'm just not sure how to do that :-/ The AFM is secured on both its sides. I'm guessing that the rubber material is so flimsy that caves in from all the pressure.
Yes, I will put something together.
That's an excellent idea. Would the computer tripped up by the fact that it's receiving more air than it's expecting, since there's more flow after the turbo than before? The only other issue I see with this is lack of space, but I'm sure it can be done.
Ben, here are some pictures of how I've connected the boost gauge to the brake booster:
http://forums.pelicanparts.com/uploa...1221652911.jpg
http://forums.pelicanparts.com/uploa...1221652923.jpg
WERK I 09-17-2008 06:26 AM
I think the "suck through" idea sounds great as well. This board rocks!!
Maybe you can pass the idea through Todd to see what he thinks? The only question I would have is when the throttle is closed under boost conditions, i.e. full throttle conditions under boost and changing gears. I wonder if there would have to be some sort of recirculation of boost, like in the 930 CIS systems.
911st 09-17-2008 06:34 AM
Couple of things on a suck through.
This is a more typical way to set up a motor. New car makers do not to a blow through.
With the Carrera 3.2 the AFM gets pegged at around 180 rwhp of air flow and mostly is not used any further to determin fueling so it is the RPM table on the chip and the raising rate fuel pressure reg that determines your fueling.
The only time there is more CFM measured at the AFM between the two should be when you let off the throttle and the blow off valve opens and vents to atmosphere. With EFI the fueling is mostly stopped when the throttle is lifted so this should not be an issue. Worst case you will spit a little flame out the exaust.
Check w Todd about this as he is the expert. It should not make much difference.
If you want he can convert you to a boost sensing system which takes the AFM out of the system altogether and you get a program to map your own chip.
mb911 09-17-2008 08:31 AM
the picture looks right to me I would check to see what your brake booster line is connected to in the engine bay
WERK I 09-17-2008 08:49 AM
Could there be a check valve in that line in the engine bay?
polizei 09-17-2008 10:24 AM
Is the line that is T'd into the boost gauge line, the same line that would be running to the engine bay?
Jerry mentioned there is one as well. Wouldn't a check valve prevent positive pressure from going to the brake booster and in turn prevent a boost reading?
Excellent information. I've sent an email to Todd to verify whether the suck through method would pose any issues and to get some figures on how much his MAP solution costs.
jbrinkley 09-17-2008 10:36 AM
don't know if this helps, but here it is
http://forums.pelicanparts.com/uploa...1221676576.jpg
WERK I 09-17-2008 10:39 AM
Yes, if there were a check valve, the boost gauge would register vacuum, if it is so designed. If you disconnect the line from the boost guage, and hook up a vacuum gauge while the engine is running, the check valve theory might prove true.
polizei 09-17-2008 10:43 AM
Given Jerry's diagram above and the fact that my boost gauge also measures vacuum, I guess it's safe to say there is a check valve. Perhaps the best thing to do at this point is permanently run the boost gauge off of a line running directly to the intake manifold.
WERK I 09-17-2008 10:53 AM
.....or move the check valve to the other side of the "T" to the brake booster side.
polizei 09-17-2008 11:18 AM
I asked Todd if there would be a problem with running the AFM on the inlet side of the turbo (between the air filter and the turbo inlet). Here's his response:
Yes. The metering is completely different. On the inlet side, it measures cfm, a lot of it. On the pressure side it also measures cfm, but compressed due to boost and the fpr modifies the signal to compensate for boost. On the inlet side, it’s pegged at about 3500rpm’s and there’s no metering left.
He also mentioned this concerning the AFM being destroyed by boost:
It’s typically more of a problem when you lift off of the throttle and the boost spike pops it. Run a really good blow off valve and you won’t have that problem. I’ve run 1.4 bar through them
And here's the info on his MAP ECU to ditch the AFM:
Our pressure sensing system is $2211.72 for the conversion to the ecu, software, tps/adapter, iat, etc. We use an unused a/d channel in the ecu for the pressure transducer, mount it inside the ecu, route the rest of the circuitry, and then use the tps/iat for other compensations. You get a copy of our Motronics calibrator with it that’s normally $995.00 by itself.
WERK I 09-17-2008 12:11 PM
Here's the check valve the 930's use, item 29, part # 191-611-933 F
http://forums.pelicanparts.com/uploa...1221682281.jpg
polizei 09-18-2008 07:49 AM
Engine:
ARP Rod Bolts - M&K Exhaust
Supertec Head Studs - M&K Exhaust
Mahle 8.0:1 Pistons & 3.3 L Cylinders - Road & Race
Valve Job and Heads drilled for Twin Plugs - Supertec
Gasket kit - Pelican Parts
Twin Plug:
964/993 Twin Plug Distributor - Road & Race
Caps & Rotors - Road & Race
Magnecor Ignition wires - Magnecor (order stock '84-89 Carrera wires for upper and '89-94 Carrera length wires for lowers with '84-89 connectors)
Andial Splitter - Pelican Used Parts Board
Lower Plug Holders - Supertec
Extra Coil - Road & Race
Lower Valve Covers drilled - Pelican User cgarr - Craig
Double Coil bracket (welded) - Road & Race
(check out this thread for issues I ran into: http://forums.pelicanparts.com/porsche-911-technical-forum/418011-twin-plug-install-question.html)
Turbo, Exhaust, Intake:
Precision SC6162SPR - TD Autowerkes
Tial 46mm Wastegate - Pelican Used Parts Board (930gt-40r)
Tial 50mm BOV - M&K Exhaust
Aluminum Intake/Charge plumbing- Local race shop
Silicone couplers, bends, elbows - http://www.siliconeintakes.com/
930 J pipe turbo manifold (modified to get around twin plug dizzy) - Supertec
Muffler/Exhaust - M&K Exhaust
Brackets for charge pipe - Nate Dog Creations (local fabrication shop)
Weld collar onto AFM to secure elbow to TB - Nate Dog Creations
.7 BAR wastegate spring - M&K Exhaust
AFM flange - M&K Exhaust
ECU programmed for turbo and twin plugs - Protomotive
K&N Air filter RX-3990-1 - Summit Racing
Oil Lines/Fittings:
Replacement hard oil Line to bottom of case - Elephant Racing
Replacement hard oil line from above line to thermostat - Elephant Racing
3 foot 10mm banjo end -3 to -4 oil line for turbo oil feed - Protomotive
2 feet of -10 stainless steel oil line for turbo return - http://www.batinc.net/ (check page 4 of this thread)
Fittings - BAT Inc and Home Depot for brass fittings
Fuel:
BEGI 2025 Rising Rate Fuel Pressure Regulator - Ebay
2 feet of -6 stainless steel line - BAT Inc
Fittings - BAT Inc (check page 4 of this thread)
Check Valve - http://www.bellengineering.net/
Gauges:
NHS (VDO Clock replacement) boost gauge And tubing kit - M&K Exhaust
Innovate LM-2 Air Fuel Ratio Gauge - Ebay
Fuel Pressure Gauge - http://www.bellengineering.net/
Air Temperature Gauge - Andial
Miscellaneous:
Spring Centered Clutch - Pelican User Parts Board
Pressure Plate - Pelican User Parts Board
Clutch Throwout Bearing - Pelican User Parts Board
Updated G50 Clutch Release Fork - Pelican User Parts Board
Reference & RPM sensors - Pelican
Cylinder Head Temp Sensor - Pelican
$500 in extra stuff - paint, carb cleaner, brake cleaner, wires, tools ... stuff
Let me know what pics you'd like to see, and I'll post them. Also let me know if i've left anything out. Also check out these threads if you're converting from a narrow body Carrera, and you're considering fitting an intercooler:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/392416-intercooler-stock-carrera-whale-tail.html
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/425318-intercooler-vs-no-intercooler.html
I'm running no IC currently, but I'm planning to run water injection by next summer.
NathanUK 09-18-2008 12:59 PM
RE: The checkvalve on the brake booster, no. 29 in the pic...
Stephen of IA sells a gauge kit to replace the clock and it comes with a special checkvalve to replace the stock one. It has another port to connect some small tubing to the new gauge so you don't have to modify/hack the car too much. I'm guessing NHS also does it.
spence88mph 09-22-2008 04:10 PM
updates? you get my elbow pics Andy?
polizei 09-23-2008 04:03 AM
Yes, I did. Thanks Spence! I ended up having a local shop extend the neck of the AFM where the elbow clamps and weld a hump onto the end so that the rubber elbow won't blow off. It works perfectly! I'll try to take some pics and post them here.
By and large, the car is running very well. I've got the fuel dialed in a bit more favorably now. It idles between 14.7-15 afr. Found an oil leak between the cam towers and the heads. It's not significant, but it's very annoying. Could it be as simple as re-torquing the nuts securing the cam towers to the heads? What type of compound have you guys used to make a gasket there? Another thing that's really annoying is that the idle is erratic. I think the throttle linkage got bent up a little during the rebuild so it doesn't want to shut the entire way. Easily fixable, but very annoying in the interim. Last night the throttle jammed wide open at high revs and kept pushing it to the 7000 RPM max read on the tach. Could've been the throttle linkage or maybe the carpet? Scared the crap out of me.
Even though I can hear the turbo spooling very early, the boost/vacuum gauge doesn't read positive pressure until over 3000 RPM. Part of this is certainly attributable to the stock heat exchangers. Do you think my compressor discharge could be too small at 2"? Do most of you guys run 2.5"? The revs still build reasonably quickly because of the compression, but once it gets up to 4000+ RPM it has serious GO (carrera cams). For those of you interested in speed comparisons: I lagged slightly behind my friend's Yamaha fz6 until 80-90 MPH then took over, and I was pulling slightly away from a new MB S600 30MPH-80MPH.
Jerry, you were right on about the front end lifting! Between that and the sound of the engine, I feel like I'm in an airplane at times.
I'll be heading up to New England with the p-car tomorrow for a week long road trip and some camping. Very excited for a vacation and a short break from all the tinkering (hopefully no problems on the trip... **fingers crossed**).
NathanUK 09-23-2008 12:09 PM
I think my stock 930 did come on boost slightly earlier than than that, maybe around 2750. I've gone with GHL headers now!
I hear you on the cams, the 3.2 carrera really comes up on the cam at 4000. My rear tyres break loose in my carrera at 4000 in 1st in the dry and at 4000 in 2nd in the wet.
You're making me jealous about the front lifting up and taking off like a plane!
jbrinkley 09-23-2008 01:45 PM
little difficult to steer the car at the top of second and third. That's what really bothered me.
911st 09-23-2008 02:30 PM
This is just my opinion but there is nothing wrong w the stock heat exchangers so long as the muffler is as low back pressure as possible.
The muffler is more where lag is reduced. The higher HP that the after market header maker talks of is had from an poor design of the wast gate circuit. This tricks the motor into delivering more boost w the same WG spring / setting.
If you are going to go to headers check w M&K about doing a SSI conversion for a Turbo. This gives you a little more HP pre boost, equal length primary tubes to help keep the heat at each cylinder more the same.
The make up of the Turbo can have something to do with how fast it comes in (compaired to how soon). A lot of builders like to use a small exhaust section w a large compressor wheel. The small hot side helps start the boost early but the bigger compressor fights this and builds a little more slowly. The bigger compressor is more efficient (less heat) and can push more air up top (higher peak HP). Full boost us usually hit by before 4000rpm and power comes in almost like a normally aspirated motor.
With this style of turbo one has to watch for over boost as it needs to move a lot of exhaust through the WG circuit. If that circuit is not big enough, there will be boost creep at the upper RPM's and put you at risk.
A Turbo with a modest hot side and a smaller compressor side like a factory K27-7200 may start making boost at the same place but will hit full boost faster and can do so by 3000rpm. However, it will max out before red line. But it comes in hard and is a blast.
On the special C2 Turbo S2 cars the factory used the 7200 compressor side but increased the hot section for less back pressure and got more HP along w C2 cams and a biger intercooler.
If you are not measuring boost at the area between the throttle plate and intake valves I would not trust your readings. Also, some motors have a special vac port near the TB that can deliver a modified boost / vac signal and should no be used.
Nothing wrong w a 2" compressor supply at your HP levels that I know of.
Not an expert, just what I found.
Flieger 09-23-2008 02:43 PM
Sorry for my ignorance, but can someone give a good techincal definition of "Boost Creep"?
polizei 09-24-2008 04:02 AM
I finally corrected the lean condition at idle last night as I found another vacuum leak. Unfortunately, it jumped from 15.3 to 13.6 AFR. I've got the fuel pressure set at 38-39 psi at idle with the vacuum line disconnected at the rrfpr. The AFR's do NOT budge as I drop the fuel pressure from there. Do you think I could have damaged the wideband o2 sensor and I'm just get a bad reading? Could the air filter be too restrictive?
I appreciate any ideas you have. Thanks.
jbrinkley 09-24-2008 05:08 AM
did you adjust the afm mix for idle conditions?
polizei 09-24-2008 05:09 AM
AFM mix? I'm not sure what this is, so I probably haven't :rolleyes: Please educate me.
jbrinkley 09-24-2008 05:10 AM
oh, boost creep is the wastegate not letting out enough gas. another way, boost to wastegate setting and then creeping up beyond that setting.
plenty of people here have a better definition I'm sure, I'm no expert
930gt-40r 09-24-2008 05:12 AM
Andy, how much did you adjust the fuel pressure to not get a reading? I don't think 1-2 psi will make a diffrence in air/fuel ratio at idle because the injector pulse-width is too small at that low rpm.
polizei 09-24-2008 05:15 AM
I turned it way down to about 20 PSI at idle with the vacuum/boost line disconnected from the rrfpr. I'm reading fuel pressure off of the return line. I wonder if it's time to view pressure off of the fuel rail.
jbrinkley 09-24-2008 05:26 AM
don't worry about all that, really. post some runs from your lm2.
at idle the afm adjusts mix with input from the nb 02 sensor, within limits.
plug you NB sensor in and look for a change in afr. I assume your NB is unplugged at the moment.
im looking for a afm idle mix thread because im lazy and don't want to type it all out.
jbrinkley 09-24-2008 05:50 AM
halfway down this thread, steve W. post
http://forums.pelicanparts.com/porsche-911-technical-forum/104495-idle-hunting-problem-continues.html
if you don't have the bosch fuel injection and engine management book, I recommend it.
I use to look at this book more than any other P car book
911st 09-24-2008 06:21 AM
As noted, at some point the wast gate can become to small and reach its capacity and can not bleed off enough air. This forces more through the hot side of the turbo spinning it higher and creating more boost.
This us partially because the compressor section of the turbo is larger than needed.
Thus, a bigger hot side, smaller compressor wheel or bigger wast gate circuit, including the pipe size can help to fix this.
On the 930's Porsche put a pressure switch that shuts down the motor if one over boosts for any reason as protection.
Flieger 09-24-2008 01:12 PM
Thanks for the explainations, 911st and jbrinkley, I understand boost creep now.
polizei 10-15-2008 05:18 AM
Hey guys,
The car is going through way too much oil so we have to drop the engine again to find the problem. I've started a thread with all the details in the engine rebuilding forum:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/435673-need-drop-engine-after-rebuild.html#post4239599
I'd appreciate it if some of you guys would lend your advice. Thanks!
sjf911 11-08-2008 08:19 PM
Great thread. It has me motivated to attempt the same thing although from a slightly different origin.
In regards to the brake booster check valve and venturi plumbing, would it be possible to dispose of the rubber elbow above the TB (and replace with a silicone elbow) along with all of the 3.2 venturi piping and the stock check valve and simply run a hose directly from the nipple on the front left half of the 3.2 intake manifold to the booster and placing a check valve in a similar location to the stock 930?
polizei 08-30-2010 06:19 PM
Hey guys,
It's been a while. I got engaged shortly after getting the turbo on back in '08 and then I got married last summer. It turns out that marriage is more expensive than a turbo carrera... But things have started to settle out for us financially, so I'm picking things back up with this project.
It turns out that my oil burning woes had two causes:
1. I've got a small leak around one of my RHS valve covers. It's dripping onto the heat exchanger and causing some visible smoke on idle.
2. The larger problem is that my gravity drain from the turbo to the crankcase wasn't exactly employing Sir Isaac's law. I've purchased an oil scavenge pump to address the issue.
Presently, I'm running the car w/o the turbo with 8.0:1 compression and the stock chip. It's just sitting right now with a car cover on - I think I've taken it out 3 times this year. Here's my 6 month plan for finishing up Phase 2 (chronological order):
1. In the short time that I had it turbo'd, I really wore down my tires. So much so that I need new ones for inspection. I'm limited by the narrow body Carrera on tire and rim width. Bill Verburg recommended Dunlop Direzza Star spec or Bridgestone RE11 with 225/45 & 255/40 in the front and rear respectively
2. Mount and install Oil Scavenge Pump. I've purchased this one per Jerry's recommendation: Turbo Oil Scavenge Pump - 12V (DC)
3. Have local shop fabricate following items:
a. Turbo to AFM charge pipe
b. Air Filter to Turbo pipe
c. Splash guard behind rear driver's side wheel (where the air filter will be)
4. Have local shop install custom methanol injection cooling system by tapping into the windshield washer reservoir.
5. Have local shop mount and install Andial Air Temperature Gauge. I'd also like a gauge to indicate the windshield washer reservoir level.
6. Dyno and tune!
7. Upgrade to turbo master cylinder and either 996 or 996 TT brakes. I know that the 996 TT brakes are overkill for the street, plus I'm not sure I'll be able to benefit from them with my narrower tires. Would I save much on weight by going with the 996 NA brakes? I planning to work with Steve Timmons on this.
Please pass along your advice! I'm anxious to hear feedback about the methanol injection, tires & brakes!
Thanks!
carslutt 09-02-2010 09:07 AM
wow, a lot of work but looking good
