It's Back
Just walked in from the garage after she started on the first flick of the key after reinstalling the motor. Just for giggles I pulled the fuel pump relays to see how long till oil pressure built... about 7 seconds of cranking. Popped the relays back in and she fired right up. A little lumpy on the idle but once I blipped the throttle she settled into a nice smooth idle.
![]() Mad props to Hirevtuner for posting the pic of his engine dolly. I made one of those before I pulled everything back apart and I was able to get the engine and trans on the ground in about 90 minutes. Took about the same to get it back in. ![]() Tranny is fixed, a few oil leaks are touched up, new exhaust gaskets all the way around, and new turbo oil line gaskets top and bottom. Oh yeah, for good measure I replaced my welded up throttle lever with a brand new one too. You guys were totally right, second time around was much easier. The omega spring took all of thirty seconds this time as opposed for the two hours I had futzed with it the first time. ![]() Will have to wait till tomorrow morning to see if my first gear flip works... wife threatened to hit me with a breaker bar if I did not shut it down immediately ![]()
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
![]() ![]() You gotta feel pretty good about now! Kudos
'79 930/934 replica 80 RSR-look(Now in Sicily) 914/6 2.7 (Projekt 908/3) 1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW D-Zug Produkte/D-Zug.com |
Thanks. But, I am keeping my fingers crossed till first drive and then probably for a few hundred miles after that. I did drink a beer to celebrate though
sudo apt-get purge 930
Good for you! It sure sucks when you put so much time and effort into something and then have to tear it back apart.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Crotchety Old Bastard
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
She looks purrrrrty!! Good job man, I hope it works well.
Now quick, drink a 12 pack so tomarrow morning comes faster- or a bottle of whisky...
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
Max Sluiter
Great Work!
![]() You will replace the Castrol GTX break-in oil with some good Brad Penn, right? ![]() I use Castrol GTX but am switching to BP now after reading the oil thread.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
1981 411 rwhp, Ruf intercooler, 964 cams, Turbo Kraft injector blocks, Extrude honed intake, 7006 Turbo, Tial wastegate, RarlyL8 exhaust, MSD6al |
After about 5 miles of test ride you'll be sporting one of these:
Dan 88 930 blk/gry |
I hit boost in first gear!!!
![]() Wow, absence makes the heart grow fonder. She is dirtier then I have ever seen her... she used to get regular baths twice a week. So now I can go start on that and get the bumper stuff back together so I can once again be street legal. Thanks for almost everyones help ![]() PS... the Castrol is break in and if you look in the bottom left hand corner you can see one of the bags with the 17 quarts of Mobil 1 15/50 in it (I have to change the 944 oil before the DE next week)
A fellow Pelacanite
Can I see some more pics of Dolly?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
Macht Schnell
Do you think the furniture dolly is better than the "Jack Gadget" sold by Pelican Parts?
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT |
Dang, it is hot outside.
I did a search for "jack gadget" and did not find anything specific. As for the jack adapters that I could find, those looked pretty cool. Especially the one that you could change the fore/aft angle to get the shift rod up high into the tunnel. However, they were a little pricey. My dolly cost me... wait for it... nothing. I just took an old furniture dolly that I use and cut a notch on one side equal to the width of my floor jack. Then I found two pieces of 3/8" plywood in the garage that we use during hurricanes and cut notches out and used eight wood screws to mount them to the dolly. I did use the piece I cut out of the dolly on the back member as a spacer since the the sides of the dolly sit higher then the cross beams. You coudl probably get away with a single 1/2" piece of plywood but I did not have any of that laying around. If you want measurements, just let me know and I will go get them. I really just copied Hirevtuners picture that he posted on another thread so he gets all the credit for this one. The motor and trans balanced perfectly on the dolly. Here are a few shots except my kids go-kart is sitting on it now and I was too lazy to pull it off. If you want specifics, I will be happy to get them but it is really nothing special. ![]() ![]() Oh yeah, back to regularly scheduled programming... I went for about a 50 mile ride and still have a smile on my face. Here she is in all her glory, nice and prettied up ready for the dance. ![]()
Macht Schnell
The Jack Gadget is at the top of this page.
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_TOLtol_pg1.htm#item3 Les
