part number help?
I need the part number for the turbo bracket to engine mount for a 930 please advise ..
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Do you mean 930 107 113 01 ??
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
I don't know is it the braket that is between the turbo and the muffler in a stock application?
Metal Guru
930 123 121 05 is the correct part number according to the PET.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Forced Induction Junkie
Which turbo, the 3LDZ or the K27-7006?
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
I don't really care as long as it puts everything in stock location for paul and a few others in on this project. You don't have an extra do you? that would save some shipping time for as you are only a few hours away
Metal Guru
930 123 121 05 is the bracket for 1978 to 1993 according to PET.
Metal Guru
![]() It's no. 5
What I am using it for is simply a clocking device so I can build up a HE for stock bolt on for turbo cars in keeping turbos in the stock location
Metal Guru
930-123-121-05 930-123-921-05 ; 930.66- S M148 The latter bracket is for the 330BHP engine with a K27-7006 turbocharger. This engine is the one used in the Special Wishes and 930 SE cars before 1987. The nomenclature, 930.66, is the engine series available for the option. M148, "Engine with increased efficiency", is the option code for the 930 SE cars, I believe. The earlier PET had all all the part numbers for the Special Wishes Slantnose cars, but you had to search like crazy to find them.
Metal Guru
My '91 has the K27 turbo. The number listed for it is 930 123 121 05, which is the number that goes all the way back to '78. That makes sense to me as the 930 engine in the 965 was carried over by Porsche from '89.
sudo apt-get purge 930
Odd because the 3LDZ on the 1989 and earlier mounts differently than the K27-7200 which is why we all had to modify the early bracket to accept the K27-7200 turbo. The bracket has to be extended as shown in the pic above.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Crotchety Old Bastard
... but the K27 was not a carry over from the 930, it is specific to the 965.
What Ben needs is the 3LDZ bracket. That is the one all 930's have and must be used for fitment purposes when designing exhaust components. It is curious that the 965 lists the same part number for the turbo bracket as the 930. As illistrated above, the turbos are different and the K27 requires a bracket mod when installed to replace the stock 3LDZ on a 930. The post-turbo exhaust system on the 965 is completely different than that of the 930, so it stands to reason that if the same bracket is used on both 930/965 then the turbo is oriented slightly different on the 965 than on the 930 and the 965 exhaust system is designed to accommodate. That also would explain why my mufflers fit differently on a 965. Interesting ...
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 Last edited by RarlyL8; 11-29-2008 at 07:54 AM.. |
Not that there will be a great number of people ordering a replacement bracket for their 965 turbo's, I think they're in for a disappointment if they do. That bracket is not going to work on a K27 without the mods mentioned. It stands to reason the bracket is different as the cold and hot sides of the K27 are dimensionally larger. It's got to be a typo error.
I can't find my old PET, but it listed the correct part # for those K-27 equipped engines.
How does one get the latest PET? Is this something anyone can buy?
I think our host sells it.
