Your comments:
Thus, just hook up the rpm switch and wire in line with the Andial boost switch. Now, the fueler will only trigger when both switch's are a enabled. T I failed to mention it, but I did have the same thought of hooking the rpm switch in series with the Andial boost switch. That way when I hit high boost before the rpms have caught up, the Andial won't energize until the RPM switch allows it. Should get rid of the mid-range pig richies. Or, just toss the Andial and let Brian's adjustable WUR in line with my rpm switch/solenoid do the same basic thing. Now in a quandry as to which way to go. Care to vote?
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
I was focused on complete movement for more fuel up top. |
This approach works ok on stock fuel heads until you do something like the IA head. With the IA you do not need boost fuel because it is already giving you 10% plus more fuel when the boost enrichment would normally be triggered. That is what created the need for the rpm boost delay. We never intended it for anything other than that and definitely not for a motor that dose not have in increased flow fuel head. I guess you could do something like that but it is not a best practices approach. The Andial was made for exactly for your use. Adding the RPM delay is a large improvement on there product to it keeping it from adding fuel on top of the factory enrichment to early. I would even set it to trigger at .6 or .7 bar but delay it with the RPM switch untell you need the fuel. This is a very good old school proven set up with just a little improvement. Remember Andial invented modified 930's. Of cource, half the fun is trying new things. Enjoy.
Signing on. I love this stuff!!!
Makes me want to go back to my engineering roots.
WTB: 964/965 Turbo stuff...carbon fibre bits, Techart wheel parts, RS/lightweight flywheel, 993 EVO uprights, G50 gears or 6 sp., 964 RSR swaybars, custom droplinks and any other cool stuff, pm me! Also a nice medium build 327 Chevy engine. Coming SOME DAY...1991 3.3 turbo, Tahoe Blue Metallic with some mods
I dreamed of a stepper motor controlled Metering Arm at one time. Went to the army surplus to lear about steeper motors. At that point I think an EFI conversion is on order.
I even though of a machined cartage to replace the Fuel Head that has a bank of high flow injectors with in it. The would basically feed through the stock fuel lines and injectors. |
Keith,
1. Here is the link to the Synchronic BOV. Very nice, very fast group5motorsports.com 2. Just talked with one of the original developers of the velocity cone for Porsche CIS. He confirmed exactly what we were assuming. He said it accelerated the metering plate faster from rest through full movement of the lever and eliminated the plate stall inside the venturi allowing full movement of the control plunger. He said this was originally seen on an old Mercedes CIS and they did some testing and then had one made for a 930 metering plate and it worked so well they used them on their race motors had them made locally and sold them through various Porsche aftermarket suppliers. Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. Last edited by cole930; 03-06-2009 at 02:56 PM.. |
YES, YES, YES! I have been wondering about this for so may years. Once I understood what we needed I knew righ away what the intent of those buggers were. We have to get one of these on a dyno for a back to back on the AFR's. I think the marketing people just did not know what they were truly for. Everone wanted less lag so that is what they tryed to tell them to do. I remember reading the pitch in the Automotion add (any one have a old copy). Another example of a good idea just getting lost. If it works like it should it will be major. Do you realize how much time money and effort people have gone to to work around the metering plat stalling? This could men no Fueler, high flow head, or other crazy stuff... for most internaly stock 3.3's up to 1 bar running biger turbos. For thouse that trully need it, it could even make the IA head tunable at the WUR w/o boost clamps or rpm switches. I am so excited about this I think I am going to cry!
Oh, and along those lines...one more thought on Andial. The control potentiometer controls the duty cycle of the Lambda valve by selecting one of 5 different positons, each with it's own set of exposed resistors feeding back to the "computer" to govern the duty cycle. I would bet that a person can monkey with those resistor values and modify the duty cycle (i.e., increase the cycle beyond stock maximum). Real simple, just have to put the ohm meter on things and go from there.
Hello !!!
Keith, this is a great idea to create a new trhread for this topic! I will take picture for you soon of the ANDIAL kit . I'll sent to you ASAP Marc, as Keith mentionned ( actually he was very kind to me and suggested this setup to me a while ago) , also I just bought a complete Andial kit (I will use the plumbing only) which I will combine with a split second AIC controller. So we will be able to share our experience if you go in this way. By the way, the AIC controller has 2 chanels. The second chanel can be use as something like an RPM/MAP switch . Via the solenoid valve (which can be drive directly by the controler), it is possible to drive the "boost line". Thus it is possibel to disable the boost line from 2000 to 5500 RPM ...then enable this line to decrease CP if required ....
965 C2T / 1991 3.3 TURBO |
dear Mark
The andial controller is very limited in it action since it can not get the MAP information. It would be relatively easy to modify some resistance inside to change the duty cycle . But it is much more convenient to do it by programming the AIC controller ...would be much easier and much accurate. the Andial controler doesn't controle the original lambda freq valve. The andial controle his own added freq valve.
Zcoker,
I just called Synapse Engineering eariler this week and ask about their new DV001 Model as it was kicked off at the 2009 SEMA show and was considerably smaller than the SB001. The new model won't be available until later this year so I ordered a SB001. They even have them on Ebay. Not hard to find. Great product. Sorry Z I thought you were talking about the BOV My Bad !!!!! This thing is probably early 80's vintage and I don't think most people had the understanding of of what it really did. The one I have is the only one I ever saw. I got it from Chris Fisher years ago. I never thought about it either untill Kevin brought it up last nite Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. Last edited by cole930; 03-06-2009 at 04:16 PM.. |
Just googled SE BOV. I watched a Utube video of it on a turbo Honda S2000. He did not explain it very well. However, that is basically what I did with a piston style adjustable aftermarket compressor bypass valve. If his is larger in diameter, It would be worth looking at in place of what I did except this would complicated plumbing. This much be plumed on between the turbo compressor wheel and throttle plate and discharge between the metering assembly and the turbo inlet just like the factory Bosch anti stall valve dose. Big picture. Using this with a drop and catch strategy to get the metering plate moving quickly transformed my throttle response off idle and from cruse.
Keith,
Now that we've investigated this thing I may have saved $600.00 for an IA fuel head mod and it didn't cost me a dime. I have never thought much of the fuel mod anyway unless your running big HP. When I get it back I'll look at getting some made. We have several good aluminum spinners here. Also like I said if you need it to do some testing let me know. Gives you another reason to buy that Turbo. I was looking a plumbing it off the 964 elbo at the CIS and direct discharge back to the intake. On my set up that's a peice of cake. Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. Last edited by cole930; 03-06-2009 at 04:07 PM.. |
If not, lets get some one to do that and validated it.
I think I used an early "adjustable" version of this Compressor Bypass Valve that I reconfigured to improve my throttle response. This I know works.
I think what is needed is an ability to adjust the spring tension. Forge looks to have some nice units with different springs to tune them. The key is a higher ratio of piston size from top to bottom and the ability to get change the spring tension. http://www.stratmosphere.com/hyperboost.htm |
