klefroid's Avatar
porsche header 930 turbo
so here are some pics of the header
Old 01-28-2010, 02:46 PM
klefroid's Avatar
Old 01-28-2010, 02:55 PM
klefroid's Avatar
Question
Does somebuddy have experience with these?
Old 01-28-2010, 02:57 PM
No first hand experience with that particular brand but the pics show me enough to walk away.
Old 01-28-2010, 06:12 PM
Drive it like u stole it.
jonesb930's Avatar
Do a search. There have been a lot of reported failures of this brand of header. Most issues involve stress cracks at the welds. I would also be very concerned at what I see inside. It looks sloppy and I doubt it was back gas welded. If any slag is left in the pipe and it comes free your turbo will not be happy. Walk away and contact Brian (RarlyL8 on this forum) and he will set you up with a proper set of headers at a reasonable price.
His contact info (no affiliation)
RarlyL8 Motorsports - 930 Turbos and Exhaust Systems
ph: (256)698-4992 Email: Brian@RarlyL8.com
Bill
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 01-28-2010, 07:18 PM
Crotchety Old Bastard
RarlyL8's Avatar
I appreciate the support but cannot touch that pricepoint. 321, backpurged welding, merge collectors, design detail, quality control and USA manufacturing simply are not compatible with Asian pricing.
Old 01-28-2010, 09:27 PM
klefroid's Avatar
Originally Posted by jonesb930 View Post
Do a search. There have been a lot of reported failures of this brand of header. Most issues involve stress cracks at the welds. I would also be very concerned at what I see inside. It looks sloppy and I doubt it was back gas welded. If any slag is left in the pipe and it comes free your turbo Willl not be happy. Walk away and contact Brian (RarlyL8 on this forum) and he Willl set you up with a proper set of headers at a reasonable price.
Bill
you right but as we known obx is a low budget header. so as you can see its not Reddy to install it. there are a few things i Will do before installing it.
I Will go into the pipes with a small cam (hd) to check the weldings and slag an make it clean. when i mount the header i Will check en fix stress. in the pipes it looks better accept the place where the turbo fits. i do not expect it Will live forever. with in two year i Will afford a special one, after a motor rebuild.
I feel not cheated for this price. and there are people giving good comments for this header. but don't expect the world from this header. sorry for the bad spell,as i am a Dutch man...
I will post the movie.
Thanks for the comments
Old 01-29-2010, 01:34 AM
RarlyL8's Avatar
That is a proper use for such a system in my opinion. If you add heat exchangers be mindful to not cover a welded joint. Probably don't need to tell you that but it is important.
Old 01-29-2010, 05:16 AM
jonesb930's Avatar
No worries on the spelling. Good plan to use the cam and really inspect the headers well. I am interested in what you find so please post what you find.
Brian, I sent you an email regarding my headers.
Bill Jones
Jupiter, FL
Old 01-29-2010, 05:40 AM
RarlyL8's Avatar
The more I think about it I don't believe I would go to the trouble to modify, or any expense, to bolt up something I don't intend to keep. If you have a Euro exhaust now I'd leave it as is until you are ready for the upgrades. That $400 may be better spent somewhere else and is likely to grow into more $$$ as you address issues. Now if you just like fiddling with things that's a different story ...
Bill I did not get an email this morning, please re-send.
Old 01-29-2010, 06:48 AM
jonesb930's Avatar
Good point Brian! This is why I was intending to leave my euro exhaust when I thought I was keeping my single turbo. I figured I would upgrade and spend the money on the twin setup as that was my goal.
Brain I re-sent to your yahoo address.
Bill Jones
Jupiter, FL
Old 01-29-2010, 07:26 AM
A930Rocket's Avatar
Someone recommended runnng a length of chain through the pips to remove any slag. And that O2 sensor location just before the turbo, DO NOT use it.
Old 01-29-2010, 01:58 PM
zaidigonzo's Avatar
anyone know who makes these? are they the same but just with heater boxes?
1984 ROW 930 turbo with rarly8 exhaust, waste gate pipe and HEADERS
K27HFS TURBO, B&B IC, 1 bar spring,LEASK WUR with rpm solenoid, fab speed intake filter, front strut brace rennline. MOMO wheel, Innovative afr 16-1 gauge, custom 930 ELGIN cam
Old 01-29-2010, 02:25 PM
zaidigonzo's Avatar
more pics of same ? header/ heater boxes
Old 01-29-2010, 02:28 PM
zaidigonzo's Avatar
Old 01-29-2010, 02:30 PM
sjf911's Avatar
Those appear to be GSF (GoingSuperFast) headers/HE's which I believe are knockoffs of B&B headers.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 01-29-2010, 02:32 PM
zaidigonzo's Avatar
yes. I took pics from their website. I thought they were just selling OBxs. Are the GSEs just as low quality??
Old 01-29-2010, 02:35 PM
zaidigonzo's Avatar
Havent heard many good things about B&Bs so if these are knockoffs of B&Bs, I suppose that answers that..................... anyone have experience with these?
Old 01-29-2010, 02:37 PM
totle's Avatar
Have always thought the GSF headers was kind of OBX with heat?
Old 01-29-2010, 03:27 PM
Boost Abuser
LOWFAT's Avatar
I have the same headers on my car only schnele brand. They look identical , been on for 2+ years with no problem.I just wanted a cheap alternative to eliminate heat and weight at the time. When these fail I will upgrade to Brian's headers most likely. For what they cost they work fine.
Old 01-29-2010, 03:38 PM
