adding swepco...which plug?
i am trying to add fresh swepco to a 1977 turbo trans. i found drain plug easy enough, but what side of trans is filler plug on? i took one plug off and it was spring loaded so i plugged it up, hoping i didnt goof anything up. its been a couple of months since that fiasco i forgot what side i removed. is spring loaded plug the right one or is it other side(passenger or driver?) thanks in advance for expertise.... kevin
Old 08-12-2009, 08:30 PM
cl8ton's Avatar
Drivers side bout the same horizontal distance as the drain plug but half way up the trans.
A bit over a gallon of Swepco will do the trick.
Rod...
2010 - 997 PDK, Black on Black, Daily driver.
1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony!
Old 08-12-2009, 08:40 PM
A930Rocket's Avatar
Should have a 17mm hex head for reference.
Old 08-13-2009, 02:19 AM
Every time I've filled my 930 transaxle to the bottom of the fill hole from a 1 gallon oil container while the car is up on 4 jackstands and very close to level, I always have a little oil left over.
Like maybe 3 or 4 oz.
Don't overfill it.
Old 08-13-2009, 11:30 AM
