Turbofrog
smurfbus's Avatar
How to muffle/baffle the WG dump pipe for track usage
Can't find any solutions over quick net search and can't use any of the baffles I have for my bike.
Hopefully some sort of bolt on light weight baffle has been designed for this I just can't find any?
A small muffler would do as well but those seem to be unobtanium aswell?
Old 01-23-2011, 11:48 PM
Drive it like u stole it.
jonesb930's Avatar
I would drop an email to Brian (RarelyL8) and see if he could make you one.
Brian Bodart
RarlyL8
Motorsports
rarlyl8.com
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 01-24-2011, 05:22 AM
IMR-Merlin's Avatar
Dirt bike muffler from a 125 or smaller 4 stroke? Larger displacement mower muffler like something that is in a ExMark commercial mower.
Neither are going to be super pretty, but should work well. Also an older supertrap would work and you can add/remove the baffle plates at will to change the db level.
Old 01-24-2011, 05:34 AM
Crotchety Old Bastard
RarlyL8's Avatar
I have the parts to do this but the project was still-born as I figured not many would be interested in such a thing.
You can use the stock waste gate muffler of course, they are offered for sale here occasionally.
Old 01-24-2011, 07:04 AM
Turbofrog
smurfbus's Avatar
Maybe you could rig up an inexpensive baffle for those who need to have 95db on some tracks?
Thats the way I'm thinking of doing this. I hope to find a MC baffle the same size but no luck so far.
Maybe something like this
http://www.metriccruisers.co.uk/acatalog/baffles.html
Old 01-24-2011, 07:42 AM
RarlyL8's Avatar
That's what the project was for, low noise level tracks such as CA and Europe. We're working on a quiet muffler for that application as well.
Yes for now you might use a baffle such as those.
Old 01-24-2011, 10:29 AM
Smart quod bastardus
fredmeister's Avatar
I will tell you something that is free.
Find out where the sound microphone is positioned on the track and lift the throttle when driving past it. This will momentarily drop boost and the wastegate will be closed.
Be careful they dont move it around to different parts of the track during the weekend, I have seen this done to discourage the idea I am offering.
You could also try directing the outlet pipe downtoward the ground to reduce the noise reaching the microphone.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 01-24-2011, 10:49 AM
Turbofrog
smurfbus's Avatar
That db_meter place is in a tower that is relative close to 1/3 of the whole track so it's a little difficult task. The track is also in a small city so it's mandatory to get the noise level down. There are groups that try to shut the whole track down.
Old 01-24-2011, 11:00 AM
Porsche 78-89 930 911 Turbo OEM Wastegate Muffler - eBay (item 260724934846 end time Jan-26-11 20:20:01 PST)
Old 01-24-2011, 11:08 AM
