Hey Roland...you must have a friend with the SBB car maintenance department ;)
Looking real nice! |
Long time since, but...
Still nothing new worth to share. While still working on my insulation (not much motivation for that job, not the result;)) I am looking for other things I want to add maybe: 1st is the ER quick change bla bla X-Brace: Elephant Racing 935 X Quickchange Strut Brace ERMP2162200 - Elephant Racing - ERMP-2162200 | Pelican Parts As I have already mounting points, I only would buy the cross, unfortunately only available with brackets etc... Because my points are not at same point, I have to cut away about 20mm at each end and recut threads inside. Does anybody has that brace installed? Wonder if there is enough beef inside for threads? 2nd I saw that Rothsport oil check valve. Makes sense, but is there really an advantage or just in case of leakages? Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI 3rd This fire extinguisher mount: http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2014.cgi?SUPERCAT_FLAG=Y&make=POR&Conte xt_make=&please_wait=N&LastVisited_input=911M&Prev ious_Section=&forumid=8&threadid=&LastVisited_inpu t=911M&make=POR&description_side=BK-R-9530+&GoSearchSideFlag=T&command=DWsearch&command= DWsearch&REFINE=Y&FORUM_REFER=&SUPERCAT_FLAG=Y&Pre vious_Section=&LastVisited_input=911M&make=POR&des cription=BK-R-9520+&GoSearch_side.x=0&GoSearch_side.y=0 Is it free of play, no noises, rattling etc.? Other issues like poor clamping force? Any experiences? |
I have an extinguisher, not that same mount, but the rattle is not from the mount it is from the handle (trigger) on the extinguisher itself.
I've got the elephant racing cross brace - very happy with it.
At the front it relies on screwing through to some substantial (3mm thick?) backing plates that go the other side of the body panel - in the inner wing. So it isn't screwed into the inner wing, it's effectively clamped to it and very strongly - the inner wing is sandwiched between the two elephant racing brackets. I've no idea if you could cut 20mm off and re-thread it - you'd be better off asking Chuck at Elephant Racing. However if you do then you're also moving slightly the point at which the two struts join each other - don't know if that would cause a problem. IMHO I would suggest if you fit it then fit what they supply in the way that they supply it |
First, I have already mounting brackets welded in earlier (see pics fresh out of paint cabine), they will also conflict with the other ones. Point of joint (ha what a nice term) will not be different, only angle, but there is no issue. BTW I asked Chuck already, just wanted to see, what others may think. Second, I have a strut bar which I like very much and therefore I cannot use the rear brackets of the ER strut. Originally, I wanted to make my own strut, but this would be quite big effort, because I like the Idea of the adjustable ends there to set a little strain. |
I have to check in once in awhile , nice to see everyone else is busy in life but your car is totally to clean Roland . Keep up the slow steady progress it will finish itself one day ...
Kozmo |
While still waiting for my X-Brace from Heigo (more later) I received some pieces. Rubber, seals etc. and a R-9530 Quick Release Fire Extinguisher Mount. Earlier I bought the SPA Extreme 1kg Novec 1230 extinguisher.
http://forums.pelicanparts.com/uploa...1476300435.jpg Of course I had to save some weight here too: Drilled the handles and made an aluminum pin http://forums.pelicanparts.com/uploa...1476300626.jpg I bought the bigger one (90mm) version, because the bottle diameter is 80mm (small mount has 76.2mm / 3"). I used hard rubber to fill the gap. As I am not really happy, I ordered now the smaller one too, plan to machine the clamp to fit my extinguisher... However, let me show some details I don't like (some of you might think I am an awkward guy, but that's what I am expecting in that price range.) First I cannot understand, why the drillings are so close to the corners, bevels sometimes cut therefore http://forums.pelicanparts.com/uploa...1476301209.jpg http://forums.pelicanparts.com/uploa...1476301239.jpg There are machining tracks where there should not be: http://forums.pelicanparts.com/uploa...1476301320.jpg http://forums.pelicanparts.com/uploa...1476301448.jpg One of the biggest issues besides the finish is the machining broke through into drilling, right one visible here, but left is affected too http://forums.pelicanparts.com/uploa...1476301596.jpg http://forums.pelicanparts.com/uploa...1476301661.jpg This is probably due too much heat when anodising / gas and therefore acid acting instead of anodizing http://forums.pelicanparts.com/uploa...1476301824.jpg Poor finish here too, no parallel surface and brow at the side http://forums.pelicanparts.com/uploa...1476301917.jpg |
Review second mount
Today I received the smaller mount. All in all the same issues, but some diffences too, just wondering abouthttp://forums.pelicanparts.com/suppo...leys/shake.gif
Handle anodized at the smaller one, clamping parts and centers not. Bigger one vice versa. on the raw parts machining quit visible (compared to the anodized parts which are satined) http://forums.pelicanparts.com/uploa...1476377066.jpg http://forums.pelicanparts.com/uploa...1476377207.jpg small machining fault vs. bigger one at the clamp (note: same measurements, so no reason for diff, make me think of different suppliers) , http://forums.pelicanparts.com/uploa...1476377424.jpg http://forums.pelicanparts.com/uploa...1476377450.jpg |
Love your attention to detail! Thanks for pointing out the shortcomings on the brey-Krause parts. Great stuff, and really enjoying what you are doing!!
After machining some weight off the BK mount and increased clamp diameter, it's ready for test fit (to compare I made pic of the bigger mount to:
http://forums.pelicanparts.com/uploa...1477171768.jpg http://forums.pelicanparts.com/uploa...1477171791.jpg http://forums.pelicanparts.com/uploa...1477171899.jpg http://forums.pelicanparts.com/uploa...1477171922.jpg |
Main reason I choose a smaller extinguisher was is size. So it will fit on the tunnel in front of the shifter. First I had to install some Tubtara nuts:
http://forums.pelicanparts.com/uploa...1477172116.jpg Mount base fits :) http://forums.pelicanparts.com/uploa...1477172197.jpg And finally the complete thing, like the result very much http://forums.pelicanparts.com/uploa...1477172284.jpg http://forums.pelicanparts.com/uploa...1477172305.jpg Now back home, because the shifter and handbrake lever are black, I willanodize the mount black too |
Nice to see some progress, gives me hope for mine!
Very, very clean |
Great work!
Anodized, bolts machined for a bit weight save and nicer finish. Ready to assemble (little detail: Plastidipped the springs to avoid scratching and noise)
http://forums.pelicanparts.com/uploa...1477224909.jpg And the final result. Looks even better than I imagine before http://forums.pelicanparts.com/uploa...1477224982.jpg |
A couple of weeks ago I decided to buy an x-brace for the trunk. First I checked the ER. Not bad, but not fitting out of box (I already have mounting brackets welded-in). Further I like it a bit more beafier there. So I asked Heigo, who made my cage too. They are one of the most expirienced regarding cage etc. here in Europe and an old Porsche near brand, still all made in Germany. I was really suprised, that an individual piece made according my measurements was only a couple of Euro more than the ER x-brace. Of course I had to wait for, but here it is, very nice piece:)
http://forums.pelicanparts.com/uploa...1478030621.jpg I have do drill the brackets to bolt down, made only M8 holes to have all options then. As my hunger for weight loss never stops, I bought some lighter battery terminals too. Almost half the weight of the massive copper ones before. Also I like the look and the fact, that the cable can be crimped. This leads me to the problem I did not expect before: No one of the vehicle electricans seems to have this F-type crimping tool... Maybe I will be lucky once, otherwise I have to make my own crimping matrix. However Hollow drilled and machined head of the bolts too: http://forums.pelicanparts.com/uploa...1478031074.jpg |
I often thought about making a new wiring harness, even I did this about ten years ago already. Reason is mainly that I not used automotive wires then (which will not be a problem I guess) and much too thick wires, almost all are 2.5mm2 and more. Quite a lot of copper weight to save here. Further I want to make a new fuse box and relay holder.
First I worked on the fuse boxes, replaced the huge nuts by Tubtaras: http://forums.pelicanparts.com/uploa...1483014718.JPG http://forums.pelicanparts.com/uploa...1483014718.JPG Lots of wire and connector I will need, here just a few I have: http://forums.pelicanparts.com/uploa...1483014812.JPG http://forums.pelicanparts.com/uploa...1483014812.JPG http://forums.pelicanparts.com/uploa...1483014812.JPG |
After many hours of bending, grinding and drilling the finished item, of course with hollow drilled bolts and aluminum Tubtaras;)
http://forums.pelicanparts.com/uploa...1483015013.JPG http://forums.pelicanparts.com/uploa...1483015013.JPG http://forums.pelicanparts.com/uploa...1483015013.JPG http://forums.pelicanparts.com/uploa...1483015013.JPG |
Nice work as always Roland , good to see you have still had some steady progress through the winter . I'm back out of the brace after another surgery on my hand and at it again in the garage myself . May have a finished product for you in the near future , wish me luck.
Kozmo SmileWavy |
Looking good Roland!
It's a nice feeling to get rid of those old relays and fuses. |
Nice to hear you're on the way of recovering well. Had no issues with health since my surgery, but life is absorbing my time sometimes in different ways, so car has to wait then. Now I hope to make some more progress than in the last couple of months. Get well soonSmileWavy |
Seriously, I just was not happy enough with the result from 10 years ago and had some money to spend for wiring, connectors etc.. as my christmas gift to myself:) I spent the last couple of weeks to make my own Wiring diagramm plus disposition and ddraft for cables, fuse box etc. They look like this: http://forums.pelicanparts.com/uploa...1483456587.jpg http://forums.pelicanparts.com/uploa...1483456587.jpg |
insane build. great work
Nice!
1. Mockup in cardboard until I get it right 2. Fabricate in metal 3. Stand back and admire work 4. While admiring, realize it could be better 5. Mockup again and re-fabricate :D |
While waiting for some more cables for my SDS EFI (thanks to Ross from SDS for great customer service once moreSmileWavy ) I worked a bit on the Instrument harness, much snow and cold here, nicer to sit in the living room now than kneeing in the car now:D
All cables crimped instrument-side. Next weekend test fit and final routing in the car: http://forums.pelicanparts.com/uploa...1484777443.JPG |
Huge weight saved
Only 1/3 left over!!!
Ok, saved 19gramms:D on fuel sender connector cover Stock part: http://forums.pelicanparts.com/uploa...1489177386.JPG Homemade, aluminum of course: http://forums.pelicanparts.com/uploa...1489177485.JPG Fitted with aluminum nuts, looks nice I guess: http://forums.pelicanparts.com/uploa...1489177533.JPG http://forums.pelicanparts.com/uploa...1489177533.JPG |
Hard core
Come on, Roland, it's summer, update time!.........SmileWavy
There will be an update soon, but only a little. Be patient. |
Off topic
Spend some time with my new PET (unfortunatly they won't get that old):
http://forums.pelicanparts.com/uploa...1497438131.jpg |
Bunnies make great pets.
That's a good looking one you got there, Roland. |
Thanks Paul
He is already about 3kg at the age of about 12 weeks, will grow up to 10kg |
Way too heavy! You need to figure out a way to "lighten" that bunny. Holes in the ear? Sic! I know, sorry.
Roland, sorry to drag this up from the past, but are you using the throttle positioner along with the MAP? I am assuming the TPS is only for enrichment? Gauges look great, BTW.
Sorry for late reply, was not online since a while... Yes MAP is main parameter, TPS only for enrichment/throttle response |
Was in Zuffenhausen for a factory and museum visit to get some inspiration;)
50years 917 exhibition. Probably the only one you will see that much 917 at once http://forums.pelicanparts.com/uploa...1563361498.JPG http://forums.pelicanparts.com/uploa...1563361498.JPG http://forums.pelicanparts.com/uploa...1563361498.JPG |
Hey Roland
Good to see you are still around. I've missed seeing your excellent work. Hope all is good with you and yours. Best wishes from Australia |
All fine, thanks for asking. Spent a lot of time doing other things, for example bought a new lathe and drillpress (or whatever you call that in english). Took quite a lot of time to install them in a smart way in my little room. Also search for the most usefull options/tools is timeconsuming. However I am done more or less now and will go on with working on the car. But no hurry, it's summertime here:D |
Hope you're well Roland, like the other folk, looking forward to more updates. |
| All times are GMT -8. The time now is 11:58 PM. |
