-   -   Another rust combat (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/634616-another-rust-combat.html)
speednme1 03-10-2013 03:19 AM
Wow! really awesome work.....you got skills my friend..http://forums.pelicanparts.com/support/smileys/clap.gif
proffighter 03-10-2013 03:45 AM
Thank you, but I have to say, I have never showed you the rejects;) LOL
@Leichtbauer:
Looks like Säntis at 1st of August (National holiday)
jsveb 03-10-2013 07:05 AM
Originally Posted by leichtbauer (Post 7319704)
100% Swiss made. The measure of all things.
http://forums.pelicanparts.com/uploa...1362907298.jpg
Yeah, you guys rock. Even your cheese is light weight :)
proffighter 03-12-2013 03:56 PM
one more DIY part
throw-out bearing guide tube (what a long name) raw and then hard-anodized. I know, some of you may now doubt, but I feel pretty comfortable, that there will be no problem, as there should be only little load on it. Further hard-anodized surfaces are quite tough and often used for bearing applications
http://forums.pelicanparts.com/uploa...1363128928.jpg
http://forums.pelicanparts.com/uploa...1363128952.jpg
http://forums.pelicanparts.com/uploa...1363128972.jpg
BarryJB 03-18-2013 08:46 PM
Roland, wow!
Beautiful, obsessive, wonderful... After busily posting on the "Rear crossmember, tower damage pics" thread I started, followed your links over here, and have been going through it all for over two hours... while nowhere near your level of dedication and patience - or skill - it's always reassuring to know there are others that also spend crazy time working on things some of which no-one will likely ever see again once installed, just because they love doing it.
Form & function... a work of art indeed, in the making, IMO way more interesting than the factory produced leather-everywhere last turbo Speedster featured in the PCA Panorama magazine recently.
Like many others, looking forward to more progress notes & pics as it all comes together.
Will post re coilover mods on the other thread!
proffighter 03-20-2013 12:30 PM
Parking brake option
I plan to fit a shut-off valve in the rear brake line. As there was none available with M10x1 fittings, I had to machine them. And I found a little weight saving too, the shim which gives the range for lever (black is homemade in aluminum, steel one in silver was before)
http://forums.pelicanparts.com/uploa...1363807316.jpg
Here assembled on the scale, quite lightweight, what you think?
http://forums.pelicanparts.com/uploa...1363807418.jpg
Concerning parking brake I have an issue with street legality. My car is approved with Recaro race seats and 4-point harness. When I am sitting and harness closed, I have no chance to reach parking brake lever. So the fact that I have a Hargett shifter does not matter at all, but I have to remove it, when period approval is made, as they say the shifter is hiding the brake lever. They do not accept the argument of not reaching anyway... Strange world:confused:
However I will remove the whole parking brake system and fix the car with the valve, but have to refit when checking next time. A few kg to save for sure
Andy911sc 03-22-2013 09:39 AM
I just had my mind warped by this thread. Excellent work!
proffighter 03-27-2013 10:52 AM
A little time back I worked on the pedal cluster, but was not happy at the end as the bronze bushes I had installed a couple of years ago just aren't like I want. They have way too much play from new (no worn axles/tubes) and they aren't smooth enough. Greasing made them work quiter, but always a mess and dirt catching then.
Now I looked for an alternative, but the measurements aren't regular. So I had to make them myself.
I choosed POM-C, because it's tough, nice to machine and self-lubing. All in all worth a try. Here is the result:
http://forums.pelicanparts.com/uploa...1364406719.jpg
proffighter 03-27-2013 10:54 AM
Oops, forgot a pic;)
http://forums.pelicanparts.com/uploa...1364406885.jpg
proffighter 04-05-2013 07:06 AM
As I always thought my EFI injector blocks are way too massive, I worked on them now.
Here is the idea. The red areas should be removed:
http://forums.pelicanparts.com/uploa...1365170120.jpg
Because I have no access to CNC machining, a friend of mine offered me to make it in his shop. But no CNC either... The idea is to define several coordinates of the x and y axis to get a bow at the end, which will be machined:
http://forums.pelicanparts.com/uploa...1365170339.jpg
http://forums.pelicanparts.com/uploa...1365170359.jpg
So we spent a long evening in the shop, me announcing the data, he operating the cutter. It took about 30 min for each block:D
No wonder, read this 3times for each block:
http://forums.pelicanparts.com/uploa...1365170521.jpg
However, block fixed on a selfmade bracket to make sure, everyone is machined equal:
http://forums.pelicanparts.com/uploa...1365170581.jpg
And the result:
http://forums.pelicanparts.com/uploa...1365170612.jpg
http://forums.pelicanparts.com/uploa...1365170628.jpg
Due the way we had to make this, surface was not that nice No pic of that mess;), so I will grind a little during this weekend before anodizing
TurboKraft 04-05-2013 11:13 PM
Looks kind of like out current CIS injector blocks, or our revised v2.0 EFI Injector Blocks. :cool:
Love the work you are doing, your passion and commitment for detail and doing it right. And yes, WAY cooler that leather-wrapped this and that.
proffighter 04-06-2013 02:00 AM
Thanks Chris!
To be honest, when I was thinking about, your CIS blocks came into my mind too and I borrowed some detail from your block;) and of course stock blocks
proffighter 04-06-2013 02:20 PM
First ones finished. I choosed black, as the manifold's black too
http://forums.pelicanparts.com/uploa...1365283198.jpg
http://forums.pelicanparts.com/uploa...1365283225.jpg
MikeD930 04-06-2013 03:19 PM
Nice work Roland! I keep thinking you have more time on your hands but knowing you don't just amazes me. Plus you got great talent. By chance have your 930 been weighed before you started this project?
proffighter 04-06-2013 04:32 PM
Thanks Mike
Yes I weighted the car before starting this time. But some of the work I made before, since I bought the car over 10years ago, I worked on it. When you look at the car in the first post of this thread, then I suggest about 1040kg with full tank. It was that weight a couple of years ago. I made a couple of things since, like RarlyL8 headers and muffler instead of the Schnells and stainless muffler, gas heater mounted, other IC, EFI conversion, etc.. so some weight added and some removed, hard to say how much now. I have no real goal except working on the car and do whatever comes into my mind. Sometimes by all the inspiration from the work of all the others here too
proffighter 04-07-2013 08:31 AM
Assembled for checking everything went as wished (and to have a feeling of success:))
http://forums.pelicanparts.com/uploa...1365348628.jpg
http://forums.pelicanparts.com/uploa...1365348656.jpg
http://forums.pelicanparts.com/uploa...1365348678.jpg
http://forums.pelicanparts.com/uploa...1365348699.jpg
proffighter 04-16-2013 01:45 PM
Today I finished the pushrod for brake, homemade everything (Aluminum of course;))
Made everything a bit beefier, like the result very much:
http://forums.pelicanparts.com/uploa...1366145060.jpg
http://forums.pelicanparts.com/uploa...1366145083.jpg
http://forums.pelicanparts.com/uploa...1366145104.jpg
http://forums.pelicanparts.com/uploa...1366145128.jpg
I made only right turn threads, but once adjusted, I won't change anyway...
proffighter 04-17-2013 01:58 PM
Received my new seat consoles for the Recaros:)
Quite a difference between the steel Recaros and the aluminum ones from Sabelt
http://forums.pelicanparts.com/uploa...1366232185.jpg
http://forums.pelicanparts.com/uploa...1366232215.jpg
And here they are mounted on the seat, like the look very much (not only me as you can see...)
http://forums.pelicanparts.com/uploa...1366232299.jpg
proffighter 04-17-2013 02:01 PM
Maybe I should turn the pic next time before posting...
http://forums.pelicanparts.com/uploa...1366232467.jpg
smurfbus 04-17-2013 10:03 PM
Nice wabbit. Did you shop around for light weight mounts? Which part number are those sabelts you chose? I need to get something for my Tillets and hopefully something light too.
proffighter 04-17-2013 11:20 PM
Yes, I compared prices. I choosed Sabelt because I most like the design of all I found. Black anodized and not as heavy looking as the alu Recaros They are expensive as all like Recaro etc... (about 175 USD for one seat), but I did not wanted a no name cheap one, as I doubt the quality (especially when it comes to aluminum)
The part number is Z200005F and they are FIA approved
proffighter 04-19-2013 09:04 AM
Visit at the body shop today
A few pics of the present status. Reinforcements, sway bar and fuel pump brackets fitted.
One side of rain gutter shaved now, not finished yet. Bigger bracket for passenger floor board, as the rennlines aren't that stable. TB holes in rear fender closed and a bar welded to the fender to reduce fender movement
http://forums.pelicanparts.com/uploa...1366387171.jpg
http://forums.pelicanparts.com/uploa...1366387205.jpg
http://forums.pelicanparts.com/uploa...1366387241.jpg
http://forums.pelicanparts.com/uploa...1366387271.jpg
http://forums.pelicanparts.com/uploa...1366387308.jpg
http://forums.pelicanparts.com/uploa...1366387339.jpg
http://forums.pelicanparts.com/uploa...1366387374.jpg
http://forums.pelicanparts.com/uploa...1366387403.jpg
http://forums.pelicanparts.com/uploa...1366387439.jpg
proffighter 05-09-2013 02:58 AM
No updates, at least to show so far, but I was one week off for snowboarding with my best ever girlfriendhttp://forums.pelicanparts.com/suppo...ys/smlove2.gif
http://forums.pelicanparts.com/uploa...1368093374.jpg
http://forums.pelicanparts.com/uploa...1368093408.jpg
http://forums.pelicanparts.com/uploa...1368093432.jpg
http://forums.pelicanparts.com/uploa...1368093497.jpg
911 tweaks 05-09-2013 04:11 AM
Hey Roland...are these pictures from St. Moritz, Zermat or the glacier in Austria near St. Moritz...?? My mom is from Thalvile (sp)...I went skiing at these places yrs ago...I hope to return some day...just breathtaking beauty up there...hope you had a good time...Bob
proffighter 05-09-2013 07:56 AM
Hi Bob
It was on the glacier of Kitzsteinhorn Kaprun/Austria
Yes, we had a very nice time. We went there for the 6th time and for sure not the last!
Do you mean Thalwil near Zurich? If so it's only a few km's away from my home!
911 tweaks 05-09-2013 12:17 PM
Hey Roland...cool you were on the glacier...I remember it being surreal when I skied on it as it was a giant slab of ice w/ no snow beyond it...I think that winter...1980 I believe...there was little snow in that area...
Yes you spelt it correctly...thx for that...she lived near the lake...
Nice work on your car here...When I travel to Switzerland, I will email/pm you before as I would enjoy meeting you, seeing your car & workshop too...!!
Thx, Bob
proffighter 05-20-2013 02:01 PM
Injury
Unfortunatly I pulled apart my lower biceps fibre completly when lifted a box a week ago (was not heavy at all). Had surgery on friday and now a cast for at least four weeks. Then another two months of physiotherapy until I can use the arm as before. The good are that it will be like new after recovery
So I can't do a lot for the next few weeks, as I have only one useful arm for a while, let's see...
911 tweaks 05-20-2013 03:29 PM
wow Roland...I feel your pain & I am sorry to read this...it must of been a bad injury to of had the surgery right away but a good thing so you can start the healing process now rather than latter...
I wish you all the best luck with your recovery & that it be speedy so you can resume your project asap...
Take care...Bob :-)
Flieger 05-20-2013 05:23 PM
get well soon!
smurfbus 05-20-2013 11:17 PM
Yep, get well soon.
proffighter 05-21-2013 02:42 AM
Thanks for the kind words guys!SmileWavy
Maybe I can do some more anodizing soon...
proffighter 05-23-2013 01:28 PM
received lug nuts. I know, a little bling bling, but had not much choice, as I have conus seat rims. Maybe I cut them anyway a bit and re-anodize in flat black
http://forums.pelicanparts.com/uploa...1369340809.jpg
Further I finished the throttle linkage I drilled. Black parts are selfmade as usual;)
http://forums.pelicanparts.com/uploa...1369340887.jpg
http://forums.pelicanparts.com/uploa...1369340911.jpg
proffighter 06-07-2013 12:46 AM
Some little progress
While I am still not allowed to use my right arm, body shop sent some more pics
http://forums.pelicanparts.com/uploa...1370591130.jpg
http://forums.pelicanparts.com/uploa...1370591159.jpg
http://forums.pelicanparts.com/uploa...1370591174.jpg
proffighter 06-13-2013 06:59 AM
more to see. One side is primered, the other just before. Painter will leave drying at least one week primered before going ahead
And it looks so sweet without rain gutter:D
http://forums.pelicanparts.com/uploa...1371131838.jpg
http://forums.pelicanparts.com/uploa...1371131880.jpg
http://forums.pelicanparts.com/uploa...1371131911.jpg
http://forums.pelicanparts.com/uploa...1371131943.jpg
http://forums.pelicanparts.com/uploa...1371131968.jpg
smurfbus 06-13-2013 12:08 PM
Looks backdated with the smooth top and I like it.
WinRice 06-13-2013 12:16 PM
Nice!
Starting to look like a car again!
proffighter 06-18-2013 07:46 AM
While I am still not able to do some serious handiwork, I am looking for some ideas what else to improve. I saw those aluminum door hinges years before and think about them sometimes... But they seem to be a bit overpriced in my eyes:
A pair is 95USD at GT, so 380USD for two doors!
Does anyone used them? Are they good or weak in some way?
Thanks for sharing your thougts:)
http://forums.pelicanparts.com/uploa...1371566784.jpg
http://forums.pelicanparts.com/uploa...1371566793.jpg
proffighter 06-26-2013 09:35 AM
Hmmm no one? Ok, I'll buy them anyway;)
@Chris of Turbokraft, are you reading too? Sent you a mail a while ago...
proffighter 06-28-2013 05:18 AM
Part needed
please check my post:
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/758285-wtb-930-turbo-heat-protection.html
proffighter 07-15-2013 01:13 PM
Transmission beam 3rd generation
On the search for improvement, I started to made a new beam once more. The first I made was just stock with a few wholes drilled and instead of rubber mounts I welded in shims. Lightweight and stiff it was, but lot more noisy tranny and vibrations:
http://forums.pelicanparts.com/uploa...1373918534.jpg
So I made the 2nd one out of a steel profile and fitted Wevo rear engine mounts. Also I set the engine 10mm lower. On this I used a 9mm spacer between tranny and beam to get enough room for throttle rubber block:
http://forums.pelicanparts.com/uploa...1373918837.jpg
http://forums.pelicanparts.com/uploa...1373918850.jpg
Now I wanted to make one out of aluminum. I spent a lot of time to find a profile, which offers the base dimension I need. Finally I found a squared one with beefed middle section. As I am no engineer, I just compared strenght of the my steel beam material with the aluminum specs, which is pretty the half and trippled the dimension almost: 3.5mm to 9mm plus beefier lower section. Further I decreased the weight saving drilles from 75mm to 53mm:
http://forums.pelicanparts.com/uploa...1373919010.jpg
Sides cut in an angle of 45°, lower 60mm (40mm left) cutt-off and drilled for mounts and some weight saving:
http://forums.pelicanparts.com/uploa...1373919119.jpg
http://forums.pelicanparts.com/uploa...1373919158.jpg
