-   -   Another rust combat (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/634616-another-rust-combat.html)
flightlead404 10-14-2015 12:49 PM
Originally Posted by proffighter (Post 8577779)
One of the best ideas I've had. Beware of buying some cheap DIY store stuff. No fun then (and lot's of waste).
On a related note. I'm thinking of building a 3, 4 or even 5 axis CNC over the winter using a Tiny-G and a chinese table engraver off ebay. Anyone here done that sort of thing or have any pointers?
Kozmo930 11-02-2015 09:39 PM
Back from the dead
Not to high jack the thread but Roland hinted awhile back about some parts . Well after I got the pins out of my hand after another surgery (4th in 2 years) I got back on our little project . Had to test out the latest mold I made to see if it would fit this time . http://forums.pelicanparts.com/uploa...1446529031.jpg
http://forums.pelicanparts.com/uploa...1446529060.jpg
I'm working on the other side now and I think I still have your address :cool:
Kozmo SmileWavy
proffighter 11-06-2015 04:12 AM
Hey KozmoSmileWavy
Nice to hear from you. Those parts are nice looking! Is there any space to the brake disc? Seems to be very close, but maybe only the pic...
Kozmo930 11-06-2015 07:24 PM
Going to make a small adjustment , the back side area is a little tight but the front side is good . Trying to move the wrap around inlet hose for clearance with a slotted mounting bolt hole so it is tight . But for the first one out of the mold it is very good start . Looking forward to seeing them on your car , the weight is next to nothing :D
Kozmo SmileWavy
proffighter 11-10-2015 05:56 AM
Originally Posted by Kozmo930 (Post 8867473)
...the weight is next to nothing
I expect nothing than that:D
Seriously I am very happy you on your effort to made some, I know how mutch work is behind tiny little ****ers (oops) like this.
PS Did you know there is an automatic function censoring my F-Word?
Kozmo930 11-21-2015 07:51 PM
LoL... just about got a little material added in a few areas to loosen it a little , and your right about being a hitch :eek:
911 tweaks 02-12-2016 06:44 AM
update possible...
proffighter 05-22-2016 11:17 AM
Update as demanded
After long time thinking how to go on with heat /noise insulation in the engine bay, I decided to use cork as first layer. It is lightweight, has good damping properties, impact and airborne noise. Took a long time to find a good quality (not that floor house building stuff from Homeworker shops). The one I use is for railway wagons as damping material. Much smoother and finer pieces, self-adhesive for better aplication. To get an more even surface for the final layer of Aluminum coated FG I "filled-out" several slots with cork too.
Long story short said, not my favourite kind of work, difficult to transfer the 3D shape on the flat cork sheets...
Here is how it looks right now:
http://forums.pelicanparts.com/uploa...1463940881.jpg
http://forums.pelicanparts.com/uploa...1463940906.jpg
quattrorunner 05-22-2016 11:24 AM
Your precision is amazing
Skillet83 05-23-2016 06:07 PM
Proffighter, you have been away too long. Love your updates.
proffighter 06-02-2016 07:48 AM
More pain in the a** work done, started floor insulation with 4mm cork. You won't believe, but none of those squares is equal or rectangular side to side:mad:
Progress so far:
http://forums.pelicanparts.com/uploa...1464878825.jpg
http://forums.pelicanparts.com/uploa...1464878848.jpg
http://forums.pelicanparts.com/uploa...1464878868.jpg
quattrorunner 06-02-2016 07:54 AM
Purdy
speednme1 06-02-2016 08:45 AM
Looks great!
TurboKraft 06-02-2016 09:22 AM
Always beautiful work, Roland! That's so attractive, I'd be tempted to not run carpet or floor mats. :-)
proffighter 06-02-2016 02:42 PM
Thank you! I am sorry, but there will be two further layers, one 2mm cork over all (not inner rockers and tunnel) and then thin lightweight carpet.
boosted79 06-03-2016 05:26 AM
I see one piece where you are off by 1mm! Great work, as always.
proffighter 06-03-2016 12:13 PM
Not off, but for weight saving reasons ;)
proffighter 06-03-2016 12:19 PM
Here an example why (together with other things) it takes that long to make progress. As I wanted to improve insulation especially at the tranny tunnel, I made a 4mm thick peace here. Taking measurements and making a cardboard "tester" took 2 hours! Another 30 minutes later, it's mounted:
http://forums.pelicanparts.com/uploa...1464981417.jpg
http://forums.pelicanparts.com/uploa...1464981440.jpg
http://forums.pelicanparts.com/uploa...1464981460.jpg
Not only due the fact of the stiffer behaviour with 4mm I will cover the rest of this area with same softer cork like used in the engine bay before.
quattrorunner 06-03-2016 01:00 PM
Holy crap that's clean!
911-2,8-RSracer 06-19-2016 03:14 PM
WOW great work !
good you are proceeding
