Great topic! like to see more of your progress.
I wish I had a friend like you ... a lot of people are looking up to you! |
You're right, I have RarlyL8 Headers without heat. The heater can be regulated. It's heating performance is 2500Watt, so enough to not have cold and defrost the windows. I doubt if it's enough for deep winter, especially as my car has no isolation etc... But maybe in a stock car it would be ok. It's a Eberspächer B1LC Compact, watch my thread too: Gas heater installation
Roland 930 Turbo '81 Too many modifications to list |
But maybe I am the only one with the same girlfriend since years
One more item done
Today I anodized the two parts I made earlier this week on the lathe for the trunk lock
A few gramms less here too ![]() ![]() Notice: I left the base plate and the rod stock (besides drilling), as they have to take quite a certain amount of load
AutoBahned
you made those 2 Al pieces on the latch?
Some more parts anodized, fuel line banjo and selfmade plug for oil tank (aluminum instead of steel)
Body shell rust removal
In the UK we have a company who get rid of all old paint and rust by immesing the shell in a tank of chemicals and then after repairs will dip the whole shell in a protective primer which will be much better than any body shop could do.
Technical Process for Paint Stripping, Rust and Underseal Removal for Cars and Industry from Surface Processing Limited I have no relationship with the company but they might get my Austin Healey body when I finish my house building |
Hi Roland
It`s a nice Project from You with many interesting details! |
After I asked about the need of check valve at front pump here
EFI Fuel system question I decided to make one out of aluminum, went out very nice. Was a bit time consuming and I screwed up the first nut (cutting thread was not perfectly angeled), second one was fine. I fitted the stock valve inserts (rubber ball, spring and spring seat), so it's an more or less exact copy of the stock one. ![]() As the banjo and hose endings are black, I went without coloring this time
Roland, that is absolutely sweet.
I need one of those end caps as I have just installed a 044 pump in my Carrera 3.0 I wish I had your machine shop ![]() Keep it coming, it is very inspiring.
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
This cap is available from our host, mine is priceless ![]() look here: http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=928-110-475-04-M100&catalog_description=Cap%20Nut%20%28M%31%32%20X%20% 31%2E%35mm%29%20%39%31%31%20%28%31%39%37%38%2D%38% 39%29%2C%20%39%31%31%20Turbo%20%28%31%39%37%38%2D% 39%37%29%20
I saw someone drilling his Hargett shifter and I looked at mine and thought:
"Why not" ![]() As it is very massive there is no risk in my eyes to save some weight here too. Here is the result then: ![]() ![]() As it is Christmas soon, I made a unique key chain out of aluminum, anodized of course as usual ![]() BTW it represents me, only my GF knows why... ![]()
Received some pics from body shop. Could be worse. I bought another 930 body with A-pillar / front crash which is in excellent condition. complete rear section including torsion tube will be replaced by donator body. Front section is about 1cm out of spec, see pic
Love the mad attention to detail! In the above pic, is that jig for a 911 or 930? The front rack mounts on a 930 are higher than a 911.
1986 911 Turbo 3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts. |
Champagne on Beer Budget
Keychain is Sweet...tail should double as a bottle opener?
Einar www.einarsgarage.com Instagram @einars_garage https://www.facebook.com/pages/Einars-Garage/375533809160797 |
![]() Yes they are higher, but here you see LH, RH is sitting on the jig... Whole front is a bit missaligned. But nothing which cannot be solved!
Roland 930 Turbo '81 Too many modifications to list Last edited by proffighter; 12-21-2012 at 11:59 AM.. |
Haven't thought about that... Maybe next time
