Wow! really awesome work.....you got skills my friend..
Thank you, but I have to say, I have never showed you the rejects
LOL@Leichtbauer: Looks like Säntis at 1st of August (National holiday)
Roland 930 Turbo '81 Too many modifications to list |
Yeah, you guys rock. Even your cheese is light weight
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
one more DIY part
throw-out bearing guide tube (what a long name) raw and then hard-anodized. I know, some of you may now doubt, but I feel pretty comfortable, that there will be no problem, as there should be only little load on it. Further hard-anodized surfaces are quite tough and often used for bearing applications
Uno Dei Molti Porschisti
Roland, wow!
Beautiful, obsessive, wonderful... After busily posting on the "Rear crossmember, tower damage pics" thread I started, followed your links over here, and have been going through it all for over two hours... while nowhere near your level of dedication and patience - or skill - it's always reassuring to know there are others that also spend crazy time working on things some of which no-one will likely ever see again once installed, just because they love doing it. Form & function... a work of art indeed, in the making, IMO way more interesting than the factory produced leather-everywhere last turbo Speedster featured in the PCA Panorama magazine recently. Like many others, looking forward to more progress notes & pics as it all comes together. Will post re coilover mods on the other thread!
85 Carrera Coupe, OBD-I 993 3.6 conversion (bottomless list of mods)—425k+ miles. 100k on the 3.6, zero blue smoke, but oh the leaks... two broken 915s But G50 and all the other bits going in early 2024 ![]() Consolation & stealth vehicle: 05 Mercedes E55 AMG S211 "No one will suspect the Spa... silver station wagon". |
Parking brake option
I plan to fit a shut-off valve in the rear brake line. As there was none available with M10x1 fittings, I had to machine them. And I found a little weight saving too, the shim which gives the range for lever (black is homemade in aluminum, steel one in silver was before)
![]() Here assembled on the scale, quite lightweight, what you think? ![]() Concerning parking brake I have an issue with street legality. My car is approved with Recaro race seats and 4-point harness. When I am sitting and harness closed, I have no chance to reach parking brake lever. So the fact that I have a Hargett shifter does not matter at all, but I have to remove it, when period approval is made, as they say the shifter is hiding the brake lever. They do not accept the argument of not reaching anyway... Strange world ![]() However I will remove the whole parking brake system and fix the car with the valve, but have to refit when checking next time. A few kg to save for sure
Local Mad Scientist
I just had my mind warped by this thread. Excellent work!
1982 Porsche 911sc 2009 Jeep Grand Cherokee Laredo X CPA-PCA Member Since 2012 |
A little time back I worked on the pedal cluster, but was not happy at the end as the bronze bushes I had installed a couple of years ago just aren't like I want. They have way too much play from new (no worn axles/tubes) and they aren't smooth enough. Greasing made them work quiter, but always a mess and dirt catching then.
Now I looked for an alternative, but the measurements aren't regular. So I had to make them myself. I choosed POM-C, because it's tough, nice to machine and self-lubing. All in all worth a try. Here is the result:
Oops, forgot a pic
As I always thought my EFI injector blocks are way too massive, I worked on them now.
Here is the idea. The red areas should be removed: ![]() Because I have no access to CNC machining, a friend of mine offered me to make it in his shop. But no CNC either... The idea is to define several coordinates of the x and y axis to get a bow at the end, which will be machined: ![]() ![]() So we spent a long evening in the shop, me announcing the data, he operating the cutter. It took about 30 min for each block ![]() No wonder, read this 3times for each block: ![]() However, block fixed on a selfmade bracket to make sure, everyone is machined equal: ![]() And the result: ![]() ![]() Due the way we had to make this, surface was not that nice No pic of that mess , so I will grind a little during this weekend before anodizing
Looks kind of like out current CIS injector blocks, or our revised v2.0 EFI Injector Blocks.
![]() Love the work you are doing, your passion and commitment for detail and doing it right. And yes, WAY cooler that leather-wrapped this and that.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Thanks Chris!
To be honest, when I was thinking about, your CIS blocks came into my mind too and I borrowed some detail from your block and of course stock blocks
First ones finished. I choosed black, as the manifold's black too
Nice work Roland! I keep thinking you have more time on your hands but knowing you don't just amazes me. Plus you got great talent. By chance have your 930 been weighed before you started this project?
MikeD '87 930 |
Yes I weighted the car before starting this time. But some of the work I made before, since I bought the car over 10years ago, I worked on it. When you look at the car in the first post of this thread, then I suggest about 1040kg with full tank. It was that weight a couple of years ago. I made a couple of things since, like RarlyL8 headers and muffler instead of the Schnells and stainless muffler, gas heater mounted, other IC, EFI conversion, etc.. so some weight added and some removed, hard to say how much now. I have no real goal except working on the car and do whatever comes into my mind. Sometimes by all the inspiration from the work of all the others here too
Assembled for checking everything went as wished (and to have a feeling of success
Today I finished the pushrod for brake, homemade everything (Aluminum of course
)Made everything a bit beefier, like the result very much: ![]() ![]() ![]() ![]() I made only right turn threads, but once adjusted, I won't change anyway...
Roland 930 Turbo '81 Too many modifications to list Last edited by proffighter; 04-16-2013 at 01:48 PM.. |
Received my new seat consoles for the Recaros
Quite a difference between the steel Recaros and the aluminum ones from Sabelt ![]() ![]() And here they are mounted on the seat, like the look very much (not only me as you can see...)
Maybe I should turn the pic next time before posting...
Turbofrog
Nice wabbit. Did you shop around for light weight mounts? Which part number are those sabelts you chose? I need to get something for my Tillets and hopefully something light too.
************************************************** ******************************* 10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg |
