3.3 Compression test. Suggestions please.
I did a compression test on my 3.3l . This engine has not run for maybe 1.5 years now. Test was done on a cold engine since its not currently set up to run.
This first test was done at room 25c / 77f . #1- 120psi #2- 120psi #3- 115psi #4- 102psi #5- 110psi #6- 120psi I was concerned about #4 results so did another test. The temp in the garage this time was colder, around 5c / 40f on a obviously cold engine. Results were worse. Also did a leak down. #1- 110psi -Leak down- 4% #2- 115psi - #3- 115psi - #4- 95psi - 9% #5- 100psi - 5% #6- 100psi - 3% I ran out of time and was not able to do the leak down on #3 and #2. When doing the leak down test, in all cases I could feel and hear air coming out of the crankcase vent at the top of the motor. So air is getting past the rings. What do you guys think. The engine is out if the car to install 964 camshafts, do you think I dig a bit deeper and check the rings on #4 or just hope that the poor reading is because it has not run in a long time and maybe the rings are sticking. Also wanted to mention, this engine was supposed to have been rebuilt in 2009 with a set of good used pistons and cylinders ( not new) and has not had many miles put on it. Who knows for sure though, it looks a bit to dirty and corroded to be true. Not quite sure what to do. Any opinions appreciated
Banned
Do you know how many miles were put on after the build? I ask, because it is possible that the rings have not seated . . . I'm not an engine building expert like others here, but I don't think that the 9% loss is something to be overly concerned with given the circumstances surrounding your engine . . .
Ronnie,
Thanks for the reply. its hard to say how many miles... car was not driven last year and very little in 2010. I would just be guessing. I also dismantled the waste gate. It has 2 wastegate springs , one large spring then a smaller spring in the center. I am worried that it may been run with too much boost. From what I have seen on these forums, broken rings from too much boost seem to give similar compression results.
If the engine is out of the car I would tear it down and investigate,
2 springs
I have seen a stock wastegate with the extra spring which will bring the total to 1 bar. In this pic, the larger spring is a 1 bar, and the smaller which would fit inside and get me to 1.2 bar. I also have a .8 spring somewhere. If I can find, I can post a pic for you, maybe it will help identify what you have. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Tough call on how to proceed from here. I too wouldn't be real concerned about a 9% leakdown on that one cylinder, give the car is cold and has not run for so long. Even if you do have a bad ring, the car will most likely still run fine and give a bunch more time and joy before having to crack into it. But the time it takes, the inconvenience of pulling the motor again, and the $$ associated with repairs all are personal choices.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. Last edited by mark houghton; 02-08-2012 at 08:23 AM.. |
beancounter
Agree. I would be concerned that something is amiss with #4, but in my experience, your leakdown would be worse if something were seriously boogered.
See below examples This piston shows signs of overheating. Top ring land is deformed. This cylinder was at 44% leakdown when tested...my engine: ![]() Similar story on this one. I think leakdown was a little better (in the 20-30% range). Not my engine, this one is fellow Pelican "Citrus"
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
Smart quod bastardus
Before you took the engine out of the car did you notice if you were getting alot of smoke puffing out of the oil tank when running the car with the cap off?
Typically if the rings are gone on one or more cylinders you will get the tell tale puff puff of oil smoke out of the oil sump tank when you run the car at idle. Its hard to tell you what to do, but would it be smart to buy a set of rings and remove the cylinders and check everything now that the top end is being rebuilt with a new cam? Worse case is you re ring it and reassemble if the pistons and cylinders look good.....your call. I would not double up on wastegate springs but get the correct spring for your desired boost setting. Running more than 1.0 bar is pushing things unless you are making other mods and monitoring the engine carefully. 964 cams are a good mod.....let us know how they run compared your current set up.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
Some more food for thought.
I had a PPI on my car and they found 4% leakdown across the board other than 14% on number 6. I bought the car and enjoyed it for ~20000 miles. This is number 6. The top compression ring was in 3 pieces. ![]() Broken Compression Ring by willtel, on Flickr I can't argue with a teardown at least for inspection sake but keep in mind no one takes one of these apart and gets away with only replacing the rings. |
this engine has not run for over a year... Good advise if you are rebuilding the top end to just go beyond but if you are not, I would leave it. The numbers might get better once it runs for a bit and lubrication gets in there and the valves do their job. I'm not an expert at all but it might simply need an italian tune-up.
David 1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit 1981 Black 911sc (sold) Last edited by Roby466; 02-08-2012 at 10:09 AM.. |
7.0:1 > 11.3:1 > 7.0:1
Herman, while doing the leak down you need to listen to the crank case breather, intake port, and exhaust port then compare the amount leakage you hear from the bad cylinders to the good cylinders. At least you will be able to narrow it down to rings/not rings. If the air is escaping from your valves, remove the valve covers and give a few taps on the rockers to see if the leakage sound changes. Could be crud between the valve and seat.
Chain fence eating turbo
2 problems with the test IMO:
1. Cold engine 2. Hasn't ran in 1.5 years You have results but can you hang your hat on the accuracy? No.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Thank you all for the opinions and advice....
![]() I had a little time to monkey around with the engine. I checked the leak down on #2cyl-4% , #3cyl-4% and rechecked #4-10% This is my first leakdown test I have ever done. I have all the intake, shrouding, cooling fan ect... off the engine so its easy to hear where the air is leaking. I stuck my ear right up to the intake port and exhaust port on the cylinder head and no air is leaking there. In all cases the air is leaking out from the crank case vent on the top of the case so the air is getting past the rings. When I purchased this engine, I was told it ran ok with no blue exhaust fumes on cold start up or when up to running temperature. Also no strange noises. These are the waste gate springs that I removed. I will buying a new .8 spring just to be sure. ![]() This is roughly the reading I get for all the cylinders except for #4Cyl ![]() This is #4cylinder
I most certainly cannot hang my hat up on these results..... thats why I am looking for advice. I dont want to overreact and start stripping a engine down because I can feel myself stepping out onto the slippery slope which results in the engine in a million pieces on a work table. Maybe all it needs is a good run .....
I would say drive it. My car ran fine and still made over 350hp to the tires with broken rings. I only pulled it apart because of excessive oil consumption.
I do like the fact that you were able to still drive 20k miles.... thats a lot of miles. I honestly would be happy with that. Its not that big of a deal for me to pull the engine later since I would be doing it myself. |
An observation: Even though you are hearing the leakage from the rings, the variance on your gauge between #4 and the other cylinders appears minor. Sometimes the compression ring gaps line up and this will affect readings.
Since the variance appears so minor I'd be inclined to run the motor as is and review it sometime in the future. Regarding your wastegate, maybe the single spring is producing less than factory boost. |
I didn't bother with a leakdown before I took it apart. Jacob's 930 was way worse than mine and was still running when he tore it down. Jacob's rebuild thread Last edited by willtel; 02-10-2012 at 09:28 AM.. |
.8 bar spring
Heres a pic of the .8 bar spring I removed from my 87. If you need one pm me. thanks Philip
Stacked springs is the old 1.2bar combination.
Another test to check when doing a leakdown: when testing a cylinder, the tap the rocker adjusting screw with a mallet enough to pop the valve open for a second. If there's some dirt or debris between the valve and seat, the compressed air in the chamber will blow it out. I can't tell you how often we see an engine that's sat a long time and has poor numbers, but a few taps to each intake & exhaust brings the numbers down to <6%. If the numbers are still high, listen for air leaks coming out the intake port, exhaust port, or crankcase breather -- tells you where your problems are.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
