A Rauh Welt-ish look for my 934 tribute
Well, as Juice and myself have found out, running a 934 tribute on the street means that either your airdam takes a ton of abuse at a ride height that looks acceptable, or you crank it up "rally style" in order to avoid the inevitable damage.
Since my car isn't a clone in any sense of the word, I decided to take some liberties with the front valance. Once again, the bodywork was entrusted to my freind and master bodysmith Kevin Mentzer who sectioned the valance approximately three inches and added a rubber/composite "lip" ala Rauh Welt as well as custom fabricated screens for the oil cooler and air inlet openings. It's not for the purists, but I like it and in the end, I guess that's all that matters... ![]()
JP 86 930/4 tribute beasty 81 sc beach beater ‘55 Belair ‘40 Ford pickup |
JP:
Looks great and I can't wait to see it on the car !!!! Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. |
Brando
That's sooooo cool and its a one and only.
Turbo powa! 1977 911s. it's cool |
beautifull work! thumbs up
Roland 930 Turbo '81 Too many modifications to list |
Well done:-). Like the look
Trond R. 1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc.. 1972 914-6 GT replica project 1986 944 Turbo |
Looks good.
It looks like the conveyor belt rubber I use on my ruf front bumper for the same reason. I bought it at a Tractor supply Co. I got the idea from the ULT Ruf Conv thread.
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
Very nice look! Also cant wait to see it mounted.
Jeremy C. Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham) ----Nothing is far away in this car!--- -2001 996 Turbo |
Wow I love that, can't wait to see it installed.
Ole Skool - wouldn't have it any other way |
Driver
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Back around 1980 there was a company that made very nice airdamns for alot of different cars out of lightweight hand laid up fiberglass cloth with an approximately 5" wide rubber lip you could fasten to the bottom edge like yours. The exterior finish was black gel coat you could paint or leave as is.
You could get them from JC Whitney for around $80 and some other places had them too. I think the name of the company that made them started with the letter P. If it comes to me I'll edit it in later. Anyway, I put one on a BMW 2002 I had back then and liked it alot. It went right down to about 3" from the road surface and eventually got scuffed up in the bottom middle area from inevitable road contacts and then I eventually removed the black rubber lip because it got to looking pretty ratty and faded after a few years of daily driving. There was a difference in how it was mounted compared to yours though. It was mounted behind the bottom edge of the fiberglass airdamn with black plastic button head screws and nuts that blended in cosmetically and wouldn't rust and then there was a semi stiff but flexable strip of clear plastic that you attached or sandwiched to the back of the more flexable rubber strip. It would keep the rubber strip from bending back from wind resistance air pressure when you were going fast so less air would go under the car and would flow around the sides of the car and through the radiator instead. I havn't seen one of those airdamns in a very long time and the company probably went out of business long ago but I was curious if I could find one with a google search and I did! Someone has a used one for a Datsun 280Z for sale on ebay. I saved a couple of the pictures of it so you could see how it was made. The plastic button head screws don't last forever and like most people did they were eventually replaced with stainless steel screws, washers, and nuts. Here's the ebay pics and ebay link fwiw, and if it's wrong for me to post them I'll delete them. ![]() ![]() |
I like that .. Where did you guys get the rubber piece from? I have been thinking of doing something similar.
1998 993 C2S Guards Red/Black 1990 964 C2 RWB project car 2016 GT3RS White Daily driver 2018 Lamborghini Performante Gegio Telesto |
Hey guys,
I am really relieved at how well this has been recieved. Somethimes you wonder if you pushed things a little too far. I will pick the valance up next week and get it mounted, then the car is off to TurboKraft for custom intercooler fabrication. Once it's all back together, I will try to get a photoshoot together of all the little things I have been playing with the last couple of years... To answer a couple of questions, the dam is a conveyor type material I scored off of ebay of all places. In addition to the front dam, I am using it on a RUF type underbody spoiler that runs side to side just aft of the jack tubes. The front dam is fastened with stainless "snake eye" security bolts that match the ones used to secure the 934 flares so there is no fear of rusting. It is interesting to note the airdam that JFairman posted and how everything old is new again. I wish I could have found one for $80.00, but with the work required on this one, I could have sourced a new turbo http://forums.pelicanparts.com/paint-bodywork-discussion-forum/694564-more-streetable-934-tribute-car.html
I used a flat piece of alu to give the bolts some more to bite into. This I got from Lowes. Check the ultimate Ruf conversion thread in the tech section. Looks good, does the job, it is sturdy and cheap. What more can you ask.
I've used EZ Lip from eBay with success. Not as tall as what you show above but an excellent ~2" extension for RSR and RUF style fronts.
http://www.youtube.com/user/pdqcarrera Last edited by pdqcarrera; 03-09-2013 at 02:13 PM.. |
Kartoffelkopf
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject |
Brando
looks great jp!!!!
ooh! I like that look...now let's get that thing on..
MD Building Products 2 in. x 16 ft. Rubber Replacement for Garage Door Bottom-03749 at The Home Depot |
That looks great.
Tony 91 964 c2 black/ Work in progress/Finally back on the road 85 EURO 930 Black slightly moded slowly reviving her 77 911tt EFI wide body red/ Slightly modified ![]() SOLD
