Waste Gate Dump Pipe Routing
So I installed a dump pipe that I purchased from a fellow Pelicanite. My question is being that I am running stock exhaust I was only able to install it with outlet facing horizontal not downwards see below. Is that okay or do I need it to face down towards the ground? Thanks in advance with any info,
Speedlimits are for the guidance of wise-men & the obedience of FOOLS! |
Brando
Some hot exhaust is aiming at your quarter panel.
Turbo powa! 1977 911s. it's cool |
Crotchety Old Bastard
For a street car that is fine as you are not on boost for long periods. I've run mine that way with no issues.
I don't know... you'll be surprised of how much heat and a little blue flame (that you hardly see), that comes out of it quite a lot...
1977 930 and a 1996 993 TT |
You could get a pair of pliers and bend the top just slightly so theres less chance of a bird flying there, or water? Or cut the ends a bit (like a flute) and depending on boost youll get diffeent sounding notes, i slit mine to play a B Minor because i like the star wars theme song and B Minor is the first note
![]() Sorry if im not much help its seven in the morning here and this is the first post i read today
Wheels Last row 1977 3.0 930 260hp built, still reassembling Row 1998 996 MK1 3.4 296hp new daily driver |
