-   -   Notable Recent 930 modification projects (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/810273-notable-recent-930-modification-projects.html)
JFairman 05-16-2014 07:16 PM
I took the rear wiper off mine recently too. I've never used it but i know some people do.
I wouldn't want to be without AC either. It's too hot and humid most of the time in S. Florida.
Ken911 05-17-2014 06:23 PM
when i was driving mine every day i used it quite a bit. humid here and widows almost always fogged over in the morning.
gumba 05-17-2014 06:50 PM
It all started with, " I don't think I have a BOV". While I was waiting for the 965 elbow and bov, I sent the k27 to Turbo Kraft for a rebuild, removed the exhaust so I could take all the smog stuff off, installed a K&N filter, oil breather/catch tank, welded a 1" pipe on the back of the i/c for the bov, and installed a new sound pad. Since I had the bumper off, I removed the big over riders, welded the holes, and painted it. I left the skirt off for now. Back on the road today.
Norm K 05-18-2014 07:33 AM
I've slipped way down the slope. Car had about 105K when I bought it (a little over a year and a half ago) from the second owner. Engine had been out once for clutch replacement but nothing else was done while they were "in there" - not even any new seals, so you have some idea as to the amount of oil and oily sludge that had built up over the years.
Started by ditching the 3LDZ and going with a K27 upgrade from Brian (Rarlyl8), along with a set of his headers. Had the other Brian (Leask) prepare my WUR, bought a Borla muffler from a fellow member and called it good for a little while. Didn't want to go too deep, as I wanted to get a good season of driving in before getting too far into things. Car seemed to run great; smooth idle, pulled strong etc., but I could sense it wasn't giving all it wanted or what God had intended it to give so I began to contemplate a top-end rebuild.
Began by buying the necessary seals and gaskets and setting them aside until I could find a reasonably good time to take my car off the streets for a couple of months (something I really didn't want to do). Figured this would be a good time to upgrade to a better street cam, so picked up a set of Web Cams' SC grind cams and added them to the parts pile. That should about do it for a nice, streetable 930, right? Right. Right, that is, until right about the time one decides that some modern engine management would help streetability, at least from the tunability standpoint, so I started compiling some more parts; 3.2 intake, injectors, Autronic ECU, MSD DIS-4 Plus CDI, some sensors and phenolic spacers from Turbo Kraft, full-bay intercooler etc. Then figured that if I really wanted the ecu to control things, then going distributorless made sense, so turned in that direction.
Finally pulled the engine and got things apart. Found some expected issues (four broken compression rings, two broken oil rings, but also found something very unexpected; no broken head studs. Could this be the only 34 year old, 100K+ mile 930 whose Divilar studs were intact? Anyway, got everything apart and was about to deliver the heads and P&Cs to the machine shop when it occurred to me (for about the thousandth time) how little sense it made to not split the case and go for the Full Monty.
So, what the hell, I split the case and delivered it, the crank and rods and the aforementioned stuff to the machine shop a couple of weeks ago. Then decided last Friday that it only makes sense, as long as I've gone this far, to twin-plug the thing. So I called the shop and told them to add that to the list.
Bought another 6 coils (going C.O.P.) and the associated connectors and will probably pick up another DIS-4 (although some say one will do the job) in the next week or so.
While I wait for the machine work, it's hours and hours and hours and hours and hours and hours and hours and hours and hours and hours and hours and hours and hours and hours and hours and hours of cleaning and painting and, well, more cleaning and painting.
I'm hoping to have the car back on the road August, but I'm afraid that's a bit optimistic...
Robbbyg 05-18-2014 08:42 AM
Can i have your rear wiper?
speednme1 05-18-2014 09:14 AM
Awesome story! that is certainly a slippery slope but unfortunately the "while I'm in there" can lighten ones wallet pretty quickly....I should know I can see through my wallet..:D
Kozmo930 05-18-2014 11:40 AM
Originally Posted by zcoker (Post 8055184)
I'm currently finishing up a front suspension refresh on the Porsche and after that I will probably start on my black turbo bmw, tuning a new Haltech ECU, writing new fuel maps for for that -- after I get another Optima battery. Went dead on me from sitting too long. The projects never seem to end!! We need some sort of motivation thread for sure.
http://forums.pelicanparts.com/uploa...1399590288.jpg
suspension ? I need that ?http://forums.pelicanparts.com/uploa...1400438400.jpg
Kozmo
JFairman 05-18-2014 12:30 PM
I want to keep it for now. Never know if I might want to put it back on for some reason.
Or I might sell it. They usually sell for around $150 with or without the arm if someone just needs the motor part.
TurboKraft 05-19-2014 09:44 AM
Originally Posted by gsxrken (Post 8068858)
BTW, looking at my pic- how many of you have removed the rear wiper assembly? I don't even know where the switch is to turn it on (seriously) and it's been 12 years so it's safe to say I could live without it.
999-703-169-40 = Rear Wiper Delete Plug
Easy to remove, just a few fasteners and a hex nut on the shaft where it comes up through the wing. Pull the fuse for it, too, and tape off the wires keeping them separated.
Fogging or condensation -- Rain-X is your friend.
citrus 05-21-2014 10:20 PM
Hello everyone I picked up my 930 yesterday from Dawe's Motor Sport and my car is finished. A quick recap Jacob and I rebuilt motor 3.4 L that basically suffered from improperly tuned motec m48. Last week the car was finally Dynowed and tuned http://forums.pelicanparts.com/uploa...1400735300.jpg
The numbers were great with 423 wheel hp and 431 on torque. This was performed on a Mustang dynamometer which happens to be conservative 20 percent but not to brag I'm really hoping for reliability and some great driving with my fellow pelicans at Turbo Palooza. Thank you again to Jacob and Chris at Turbo Kraft as well as Dawes Motor sport. Some more pics http://forums.pelicanparts.com/uploa...1400735844.jpg
http://forums.pelicanparts.com/uploa...1400735867.jpg
http://forums.pelicanparts.com/uploa...1400735890.jpg
http://forums.pelicanparts.com/uploa...1400735913.jpg
http://forums.pelicanparts.com/uploa...1400735948.jpg
jwasbury 05-22-2014 04:36 AM
Awesome John! Such a long time coming. I'm happy that it is finally on the road again. Many years ago before we tore your engine down, you were disappointed with the car's performance. What about now? How is the drive?
For context - the teardown January 16, 2011
http://asbury.smugmug.com/By-Land/My...DSC_5395-L.jpg
930 "yard sale"
http://asbury.smugmug.com/By-Land/My...DSC_5433-L.jpg
Piston damage
http://asbury.smugmug.com/By-Land/My...DSC_5432-L.jpg
http://asbury.smugmug.com/By-Land/My...DSC_5445-L.jpg
speednme1 05-22-2014 05:22 AM
That's great John! as Jacob asked how was the ride home?...btw cool pics..
onboost 05-22-2014 05:58 AM
Originally Posted by gsxrken (Post 8068852)
My TK longneck landed safely. It's a serious piece in the black anodized matte. I do notice in mentally planning the install that a few more things will attach to the intercooler itself, so I guess occasionally removing it will take a little more disconnecting than the stock one.
That TK intercooler is a schweet looking piece.. Something to add to my IC collection down the road.
I removed my rear wiper also in changing to extended tail. Basically just left it on the stock lid in this case. R & R is fairly simple.
SAY - 642 05-22-2014 06:00 AM
That's Awesome, John :cool: Your car is really clean, I saw it at the shop !
gsxrken 05-22-2014 06:05 AM
John (citrus)- congrats on getting it all back after such a long layover. Jacob, you're becoming like a midwife. Lol
Any details on the air filter setup in your pic? Not the typical K&N sitting on top of the air meter... What sort of elbow are you using to get a more cylindrical filter on there?
krasuskyp 05-22-2014 06:16 AM
John!
That's wickedawesome news today!!
Really happy you got it done and are pleased w/ the results - that has been a looooong ride for you there. Jakester, fer hire! FTMFW!
Verymuch lookin forward to piling on some WOT miles together come July my friend. Matt in RI will swoop thru my area and we'll snag you enroute to PA. Looking increasingly like Mark'll fly into Newark and I'll avoid Joisey shiity Fri p.m. commuting mayhem altogether.
The caravan out 84 together will rock, fersure!
And I've said it before / sayin it again about yer car - DAYUM :eek: Just stunning.
btw - which exhaust is that? Nearly looks like my Rarly dual out but PC'd black? Diggin it...
ps. that snail looks familiar :cool:- I snag'd what appears to be the same one:
https://lh4.googleusercontent.com/-N...0501140716.jpg
really can't wait to fire up my biitch and see how she BLOWS! Looks like some promising output... I was guesstimating ~ 400/400 crank and appears I may just see that... wooot!
onboost 05-22-2014 06:29 AM
^^ +1 John, yes congrats.. must be an awesome feeling getting it back to road. I'm looking for that feeling this year as well.. cause its surely been a "long layover" for me,
krasuskyp 05-22-2014 06:43 AM
^^^BELIEVE IT WHEN I SEE IT^^^ http://forums.pelicanparts.com/support/smileys/wat4.gif
tickfrickinTOCK dewd... July COMETH!!!
(I know you just knooooow you deserve some well-intended majorbaulbustage on this matter, and expect both no arguments and full compliance!)
come on brutha... git'rDUN fer tP'14 already wouldja? Least we finally did meet and have that 7yr overdue BIER heh heh... http://forums.pelicanparts.com/suppo...s/beerchug.gif
speednme1 05-22-2014 06:47 AM
Ken, John is on efi...no more air meter....about time you get on the bus too...lol
onboost 05-22-2014 08:12 AM
Originally Posted by krasuskyp (Post 8077487)
^^^BELIEVE IT WHEN I SEE IT^^^ http://forums.pelicanparts.com/support/smileys/wat4.gif Ha! So will I! There is hope since I'm not working on anything for anyone else currently, and refuse to do so.
Wish I could spot some more pics but cant get them to load.. oh well.
tickfrickinTOCK dewd... July COMETH!!! Gettn to it as I can..
(I know you just knooooow you deserve some well-intended majorbaulbustage on this matter, and expect both no arguments and full compliance!) Uhhhh, yes-sir :p
Yeah, it was good to catch-up and have a brew.. hopefully more to come!
