Wanted pristine but broken Dilvar head stud
I want to take a look at and have a materials engineer evaluate one or more failed Dilvar head studs. It might help to have one that has not yet failed. The perfect example would have no other damage or corrosion, but appeared to fail for no good reason.
I would assume many engine builders have a bucket of the things lurking in a corner.
I will post all details of the informal report I get. I hope to be able to have a chemical analysis run at the least so we all know what the heck this stuff is made of. I assume it is a variation on Kovar a Nickel-Iron-cobalt alloy.
thanks
Old 01-29-2015, 02:19 PM
totle's Avatar
I have, but I live in Norway. Where are you?
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 01-29-2015, 03:13 PM
I live in North Carolina, USA. I am betting there is someone closer.
Old 01-29-2015, 03:19 PM
Bland
unclebilly's Avatar
I doubt it is kovar given that kovar has a very low thermal expansion and the thermal expansion of the studs must roughly match the material of the cylinder and head to ensure consistent clamping force of the gaskets during the thermal cycling of the engine during operation.
My first patent was for a thermal clamping mechanism for a solid oxide fuel cell stack. In many ways, the system is very similar to the head studs on a 911...
Old 01-29-2015, 04:46 PM
IMR-Merlin's Avatar
Holy crap, do we have a rocket scientist among us!?!?!
Or is that electrical?
Old 01-29-2015, 04:52 PM
David I'm in NC and just pulled some this week - shoot me a PM.
Old 01-29-2015, 11:56 PM
No maaaan, that's spelling... :-/
Old 01-30-2015, 07:09 AM
Crotchety Old Bastard
RarlyL8's Avatar
To what end?
I can tell you what you will find after the failure mode evaluation, heat stress and oxidation fatigue.
We have an engine apart now where the studs were all intact. The mechanic saw a rust spot grabbed it and snapped the stud off in his hand.
Old 01-30-2015, 08:49 AM
I have posted a few threads on this subject on the same thread cross-posted on the Engine Building' Forum.
I hope these comments add some value.
Old 01-31-2015, 03:03 AM
Banned
Chris, I've just read your posts in that thread and they really answer a lot of questions about why those studs are so problematic - thanks for taking the time to share all that info!
Old 01-31-2015, 11:27 AM
RarlyL8's Avatar
One of the issues with Austenitic precipitation hardening stainless steels is that they do have a strong tendency to suffer from Stress Corrosion Cracking (SCC) particularly in the presence of Chlorides. The relatively high level of carbon found in Dilavar does it no favours in this respect.
I think that is what I said, only in English.
Old 01-31-2015, 02:57 PM
Bland
unclebilly's Avatar
What! That was a bunch of gibberish!
SCC is stress corrosion cracking and can be from chlorides, H2S, etc. Carbon is it's own element and not a chloride. Chlorides have the element Chlorine present...
Old 01-31-2015, 06:58 PM
RarlyL8's Avatar
Doesn't matter what the cause is, stress cracking, fatigue, oxidation, etc are all known contributors to dilavar stud failure. This is common knowledge. I'm just curious what the poster is hoping to gain from an analysis that isn't aready known. Maybe just doing it out of curiosity?
Old 01-31-2015, 07:51 PM
