Chain fence eating turbo
^^^ Purdy
Old 08-17-2016, 06:07 AM
930/66's Avatar
Update
Some work with the Silicone Hose Adapter for Intake 4" to 2.75":
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods
Old 08-21-2016, 06:40 AM
930/66's Avatar
Fitting Restrictor
I bought the fitting restrictor for a AGP/Garrett T Series Twin Ball Bearing turbos. It has the properly sized oil restrictor built in. The threads are 7/16-24 Inverted Flare.
The PT has orginal a oil feed restrictor, they say you don`t have to remove it.
It has a 1/8" NPT female thread, so I had to modified the thread.
I bought a 1/8" threading iron to make it fit.
Old 08-21-2016, 06:56 AM
size
what is the size in the oil feed restrictor?
Old 08-21-2016, 10:06 AM
Amazing how little oil is needed on these new units!
Old 08-21-2016, 11:20 AM
930/66, run it with an unrestricted AN fitting first and see if you have drain/smoke issues, and if not leave it as is. If you DO, then gradually restrict it down (we use nitrous jets in a machined male AN fitting) until it is happy. The restrictor fitting you have is for GT water cooled turbos - The only cooling media your turbo will have is the oil feed, let it have all you can get away with.
moty, those gold restrictors usually have an .035-.040 hole
Old 08-21-2016, 11:22 AM
On my PT 67/66 I did not need to modify although it is, I left everything of origin!
Old 08-21-2016, 11:32 AM
930/66's Avatar
Speedfab and pat rufbtr did you run it with the original scavenge pump?
Old 08-21-2016, 12:22 PM
Yes !
Old 08-21-2016, 12:24 PM
930/66's Avatar
Old 08-21-2016, 12:33 PM
Yes X2. Precision will tell you NOT to restrict the oil feed to that turbo in any way. If you use a -3 feed line that will take care of the restriction unless your oil pressure is insane. Factory 930 scav pump will deal with quite a bit. That factory 3LDZ setup with its old school one piece turbine shaft bearing had nothing but fitting size restricting oil flow.
Just as a PS, if you end up with a smoke issue only on startup, don't restrict anything. Put low popoff pressure check valves in the feed and drain (after the accumulator tank if you have one) lines so that oil doesn't gravity feed or backflow into the bearing housing after the engine is shut off. This is a common issue that makes people "put a bandage on their elbow for a sore on their knee" so to speak.
Looks good, good luck with it!
Old 08-21-2016, 12:47 PM
930/66's Avatar
I ordered a fitting without restriction and will check it when i receive it.
Old 08-30-2016, 06:51 AM
930/66, I just wish to warn(prevent) you to be very careful at the time of the tightening not to turn(shoot) more the basic join, in factory he(it) is squeezed(tightened) in a precise couple. One of my friends with fact this error.
Old 08-30-2016, 08:07 AM
930/66's Avatar
Oooo Yes i`m careful with that!
Old 09-22-2016, 12:13 AM
930/66's Avatar
Change to unrestricted AN fitting
Thanks all for your help!
I change to run it with an unrestricted AN fitting no drain/smoke issues!
Old 09-22-2016, 12:23 AM
930/66's Avatar
Installation PT Turbo
Some Picture from the Installation:
Old 09-22-2016, 12:28 AM
930/66's Avatar
Installation Muffler
I ordered an adapter for the right position (Muffler)
First start and warm up (idle at 900rpm) no smoke issues
Now i have to drive.....
Old 09-22-2016, 12:33 AM
Suspense........
Old 09-22-2016, 03:17 AM
puddy's Avatar
Well then, how does she go??
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 09-22-2016, 03:53 AM
We neeeeed to know.The suspence is killing me.
Sent from my SM-N910T using Tapatalk
Old 09-22-2016, 12:12 PM
