Chain fence eating turbo
640hp capable turbo. Should be plenty and spool like lightning.
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods |
I do not expect too much!
inlet pipe is a modified original one. I anticipate better boost response. I had a twin scroll header from you with 38mm tubes. I`m back of my Fabspeed Headers with smaller tubes (faster exhaust velocity).
![]() I now twin scroll headers with a twin scoll turbine housing gives a better response. I had previously fabspeed with good result`s without twin scroll. PT Turbo has a twin scoll option (but not with 4bolt).
Mighty Meatlocker Turbo
Modify Compressor inlet
To fit my modify original inlet pipe, i also have to cut my compressor housing...
don`t hit me ![]() ![]() ![]() ![]() ![]() ![]() ![]()
You sir, can wield a hacksaw!!!
Wow, you've got more balls than I do, I would have modded the intake. Nice work with the hack saw.
I can't even cut PVC straight with one.
I'm not exactly sure what is happening here but that isn't stopping me from watching. |
Metal Guru
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Having a TIG welder is easy, knowing how to use it is a completely different story.
I must of went through 4 pair of gloves learning how to use one.
Sent from my SM-N910T using Tapatalk |
No a tig welder,i went 10 pairs with the hacksaw.
![]() Sent from my SM-N910T using Tapatalk |
Ohhhhhhhh.
![]() I'm sure I've been through 200+ 300CF Argon cylinders in my life, and I'm still learning. Don't even sweat that. ![]() Last edited by Speedfab; 08-17-2016 at 12:08 AM.. |
Thanks for the nice hacksaw
Picture before assembling cold and hot side
Air-cooled, dual ceramic ball-bearing center housing:
![]() Compressor: ![]() Compressor housing inside view: ![]() Turbine: ![]()
