Chain fence eating turbo
Thoughts on using a "header" evap system over an AOS?
Some of you mentioned I needed to run an AOS like the 930 has (I'm a 3.2 Carrera).
I'm not a fan of clutter and lots of hoses in the already cramped engine compartment, and thought a header evacuation system might work. For those who don't know what it is, on a naturally aspirated engine, it is simply a small pipe you weld onto a header collector (in my case, on the tailpipe) that provides a vacuum as the exhaust passes by. This is then connected to a hose from the oil tank, that for my car was connected to the airbox. Lookey here: ![]() Any one tried this or know how well it would work?
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel Last edited by Tippy; 03-16-2017 at 08:45 PM.. |
I think it would only work with a zork tube and not an actual muffler. but hey it might be worth a try.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
Not in the muffler, rather the taipipe
Crotchety Old Bastard
What is AOS?
Some mufflers create back pressure. Scavenge systems are typically used on high powered N/A engines that create excess internal pressure. Doesn't work well with a muffler due to back pressure. Turbos also create back pressure.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Air-Oil Separator
You need to find "the" spot where the speed of the exhaust gas is high. High speed results in a low static pressure, creating a scavenging effect.
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
Used that on diesel trucks running straight thru mufflers, works well tied into the downpipe. The old Cummins just have a "draft tube" that is daylighted. On these you could put it between the turbo and muffler if using a straight thru or in the tailpipe, pressure delta between pre and post muffler on a straight thru is essentially zero.
edit - keep it downstream of the WBO2. Last edited by boosted79; 03-17-2017 at 05:20 AM.. |
AOS were not present on all 930s. I didn't have one on the Red Rocket and there was no need. The oil tank vent hose attached to the OEM air filter mail box. I canned that box and ran a small filter sitting on top the air meter assembly. Ran both stock breather hoses (one from the oil tank and one from the turbo) to that air filter. Never saw the first hint of oil from either one of them.
The Gray Slant has one of these separators but I pulled that hose and did the same thing. No issues.
I ran the header evac on my engine for awhile but it would pull oil with it and drip out the exhaust pipe. So I ran vent to tank and vented the tank. Some engines I don't think you can vent the tank.
3.3 ltr, stock compression, efi, twin turbo - no intercooler. |
Worst I have to lose is diconnecting and capping if it sucks oil out.
Tippy -- what's the problem you're trying to solve?
I've built many 3.2-based setups without an AOS, no issues.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
bad oil rings, valve guides?
lifting heads?
A 930 AOS wouldn't hurt. You'd have to add the AOS drain port to your factory oil tank.
A 3.2L setup with a restrictor cone in the tank vent out also works, and route the tank breather high to assist in oil vapor condensation and run back. From there it can go down to a catch can, breathe out below the car, etc. Q: are your Total Seal rings gapless?
Not gapless, standard
