Cam Tower Can Bearing Surface
1972 2.4T Build....or should I say pre-build...
1.) Is this normal surface wear on the cam bearing surface?
2.) What is the purpose of this small pin? (if it is a pin…)
Old 03-18-2019, 01:06 PM
Walt Fricke's Avatar
It doesn't look bad to me, but others may have other views.
The "pin" is a plug for the drilling which takes the lubricating oil from the spray bar (assuming it is installed with the correct orientation) into the bearing below. If you stick a finger into the bearing area you can feel the hole.
Old 03-18-2019, 01:15 PM
