I need a roller.
Sell it to me less the motor and trans.
PCA, POC & SCCA long time Member |
The 9 Store
If you want to save the case, I would call Ben/MB911. See if he's willing to take it on. If so, tear it down, box it up and ship. Shipping is probably $50-60 each way. Since he's a pro welder and also understands the details needed for the correct fix of a Porsche engine, he's one of the few people I would trust to do it right.
All used parts sold as is. |
Ollies also has a lot of experience. I have a sand cast case with a gap between the a spigot and the case parting line up top. A rod end flailing around can saw quite a slot in a case. They told me they could fix this - they'd cut out a patch from one of the various even worse damaged cases they have, machine things so the patch would slide right in, weld, machine, and the case would be fine. As it happens, I have a couple of these cases, so didn't need to have this done, though maybe at some time I will so I can sell a functioning case. A damaged case like this probably isn't worth much.
O think they are in Arizona these days, if that's more convenient than where Ben is. |
Updates...
Stopped in at my local machine shop, showed them the pics, and although they'd like to see it in person, they were pretty confident that it was fixable. The process they said they would go through was similar to what several of you mentioned:
At the same time I'll have them check the bearings and we might as well do the top end and check the pistons, cylinders, and rings. If I deliver them the short block it would be between $300-$500. Seems reasonable. I think JB weld is out in my mind because the crack goes through the drain plug which means that won't be sealed nearly as well as it once was. |
The roller is my favorite part of this car, 1986 Moss Green over Tan
Sounds like a good welding plan. If I remember the architecture correctly,the crank bearing webs are mostly if not entirely up higher than the cracked areas. Your crank and existing main bearings ought to work as jigs - hard to see that enough heat would get to the crank to make it break a sweat. I suppose a steel bar of exactly the diameter of the main bearing journals might be better, as for this purpose you don't want the clearance built into the regular crankshaft assembly.
@Catorce, have you priced out what a basic 3.6 build might cost using one of your blocks and with your discount on LN Engineering products and whatnot? I'd love to stop by sometime and see what you guys are doing since you aren't too far away. |
I don't yet have prices on the LN stuff, but I can tell you that it will be cheaper than what he lists it for retail, because LN bought a bunch of my cases and we are trying to work together. There are only 4 production slots left at $5000 per case, and beyond that I have two good sources for parts to finish the motors - LN as already stated for P&C and Autobahn Dismantlers in San Diego who parts out all the Singer stuff. They have like 49 good cranks and tons of quality parts to make a 3.6, and once again, through me, they will be cheaper than a direct sale from Autobahn because I worked up a special deal with them. I am in San Juan Capistrano if you want to see the case progress. Not done, but lots to see and compare with a stock case. PM me for contact info and thanks for your interest. Oh, and website in my sig has all the details and latest updates. |
Try not, Do or Do not
I'm not sure where you are on this project but I have a left/distributor side case half I could sell you. Cheap
The other half has a magic window Competition Engineering could match the cases if that was necessary.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 04-05-2019 at 10:01 AM.. |
Hey Henry, awesome! Glad I made this thread and you found it. I sent you a PM.
(man/dude)
Hell yeah!! Pics please?
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Ask and you shall receive... I started a build thread: Project Avocado - 1986 Moss Green 911 Rebuild
Who doesn't love a good resurrection/redemption story? |
More pics, just because. It looks like the drain plug has had an insert installed, you can see from the closeups. That probably added stress to that area, then something hit the bottom of the case and it cracked all the way across.
Still haven't decided what to do. I think I would like to do a 3.6 swap, which means that I'd be selling this one. If I am going to sell it, the questions is what sort of trim should it be in? Sell it as is, rebuild it myself and sell, or have a reputable shop (like Competition Engineering) rebuild it and then sell? What do you all think? ![]() ![]() ![]() ![]() ![]() ![]()
That is some cracking. Wow. Both sides, across the two halves!
I hadn't noticed how symmetrical the two castings are, though. What about you have all the cracks welded, weld up the oil drain hole (because the crack goes right through it), and drill and tap the other side for your drain. It will puzzle some shop guys doing an oil change, but they'll figure it out when they see the welds. It almost looks like a downward force did this. What if someone tried to screw in an iron pipe thread tapered plug, used a lot of force, and that fractured the case? It looks like it started at the drain bung. Though sending a crack across an interface to the other side? The shop doing the welding ought to be able to see if 1) the crank journals are currently properly aligned, and 2) see to it that they stay aligned throughout the welding. 1) should be some assurance that the force which caused this cracking didn't distort the middle part of the case. |
Schleprock
The threaded insert is in every engine case. See the parts diagrams below and I highlighted #46
Kevin L '86 Carrera "Larry" |
I have said it before and I will say it again. Throw the case away. Replacement 3.2 cases are plentiful on the used market. They are not hard to find like 3.6 cases are.
To reference Smokey Robinson I second that emotion, looks like a anchor to me.
I'm no expert, but if I wouldn't feel comfortable driving a car with cracks that large, that had been welded. I think it should be discarded.
Sorry. |
7.0:1 > 11.3:1 > 7.0:1
Zero evidence anything "struck" the bottom of the case.
Over tightening the drain plug wouldn't crack the other side of the case. Had water in it then froze? Something gone down inside the engine? Edit, now I see the scratches on the case. Seems minor given the damage. |
