Awesome Henry!! What is the green material on the cylinder base as the piston is being inserted please?
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS Last edited by Steve F; 10-25-2019 at 06:44 AM.. |
Curil T sealant
No physical quantity completely explains its own existence |
Thank you.....Henry, sorry I spelled your name wrong....fat fingered it
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
That is the cleanest straightest line of Curil T I’ve ever seen. I get it all over the place. Henry is a Curil T artist. Props
Tony |
Thanks Henry
John Dougherty Dougherty Racing Cams |
Gorgeous!
Very nice. Did I miss the fine print (asking price)?
Of course, if I have to ask ............ Sherwood |
Try not, Do or Do not
Singer (Ed Pink) stratosphere numbers.....no Shade-tree numbers.....no again.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Henry do you have your cases vapor cleaned? It still appears that some controversy remains ,as to whether its "safe"
Spent the afternoon at Henry's shop and this engine looks even better in person. It's a work of art!
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
Jee-zus!
Always a tasty build from Supertec! Thx for sharing!!
RGruppe #180 So many cars.. so little time!! |
Black and Blue
thanks for posting! Awesome build, I bet it pulls like a beast!
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Not high butterflies, but here's my beautiful set of rebuilt throttle bodies for the 70E sporto I'm putting back together. Henry and his crew do some nice work.
Constitutional Liberal
There's a lot going on with this pump. Can you tell us about it?
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
Call 911
Stunningly beautiful work Henry! Thanks for your detailed post.
Dave Kirk My Porsche restoreth my soul. |
First the RSR replica cover was designed and manufactured by Aaron Burnham exclusively for Supertec. As you can see, it's work of art. It varies from the original RSR cover in that it has a boss to mount our enrichment device. The original thermostat can also be mounted. ![]() This is a cable operated enrichment device that allows the drive to control the mixture for start up. This is the 3rd generation and we believe the improvements move it to the next level. If you own a 1st or 2nd generation device, we would be happy to up-grade yours for no charge. Simply send it back ![]() Years ago we decided that hot engine oil in the pump made sense only if you ran a cold start thermostat. So with a enrichment device, sealing the pump was a no brainer. ![]() As the pump heats up, pressure builds inside so if you seal the pump you have to run a breather. We made this breather a bolt on item the make it user friendly. ![]() The fuel fitting were originally designed to accommodate the tight space engine compartment on a 917 replica. We were so happy with the results we decided to add it to our list of products. ![]() Making custom fuels to match the fitting was the logical next step.
fantastic!
1975 911S Targa Silver Anniversary Edition |
Nice looking bits there Henry!
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Henry, tell us a bit more about the ITG vs the K&N filters used in your earlier high performance builds please.
Do the ITG’s have superior air flow? Does it just come down to aesthetics? I note the ITG’s come with base plates that allow custom mounting/machining to mag, plastic or individual stacks to match the intakes. This seems to be more flexible than the K&N option which is predrilled for carbs. Regards, Andrew |
First, dyno sheets show an increase in performance with air filters installed vs. no air filter. We did not do a comparative dyno run with K&N. Aesthetics is always a consideration. ITGs offer high quality filtration with a "period correct" feel. Perhaps the largest factor is the universal appeal of the ITG. They allow us to custom fit them to a plethora of custom intakes. We're really happy with the way they fit on our custom high butterfly stacks. With ITG air filters ![]() Without air filters ![]()
