This is definitely the "sharp end of the stick", as my engineer Dad would say, and a pleasure and priviledge to see...behind-the-scenes peek.
Basic question: would the engine make better numbers WITH the filters because the filtration media somehow creates favorable characteristics to the airflow...as in, the foam either straightens it out or swirls it up? Thanks, John/CT |
I want one!
Try not, Do or Do not
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
I just had a customer as m about this build so I thoughts it was time for a refresher.
We build more 3.2 Short Stroke motors now...More is better ....right?
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 12-12-2024 at 10:28 AM.. |
Our newest version of high butterfly air filter stacks.
We can offset the filter bases to allows for better fitment. Left side towards front pulley and the right side towards the flywheel.
Black and Blue
Henry,
is this motor on an SC case? thanks for posting!
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Both engines were built using an SC engine case.
The 2.8 SS uses a 66mm SuperCrank and the 3.2 SS uses a 3.0 70.4 mm crank. 2.8 SS is a 95 X 66 mm Bore and stroke. The 3.2 SS uses a 98 X 70.4mm bore and stroke. They both use a version of a 130mm GT3 rod.
