For ITBs, we have built a few motors with the Jenveys and really like them. We have also used PMO's but found they did not make quite the same power on similar builds. The PMO are very easy to set up mind you. The Jenvey's are also easy, but take a bit more time. I am also quite intrigued with the Rasant Products ITBs. They look very similar to the Kingsler being used on the Singer and feature Idle air control which is nice. They also are available with an adapted 964 or GT3 plenum. Would love to do some testing with the plenum to get a first hand look at what happens to the power curve (have seen conflicting data). Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Jeff,
The Rasant's ones look different to the Kinsler ones: https://kinsler.com/Shop/product/porsche-itb/ https://rasantproducts.com/rasant-products-intake-system-is-6-individual-throttle-bodies/ They both look good though and I hope you can do a itb comparison with and without a plenum soon. |
Calling motor builders,.While on the 3.4 subject.... i am ready to upgrade my twin plug 3.4, Je 10.5, GE 60 cam 46 pmo motor to 12.5:1.
My quandary is should i be going to a GE80 or more agressive still cams and 50 PMOs? Full Areo slant nose Track,hill climb ,sprint use car, 2100lb, that i currently rev to 6500 RPM. Any one have dyno sheets on these options. Experance to share? Thanks ![]()
aero package
I like the front treatment and the rear undertray.How about a shot of the rear straight on.More compression to 12.5 never hurts.Fred
The rear defuser is fed by a flat sculptured floor the front splitter has 2 defuesers built into it.Great lap time improvements.
Webby ![]() ![]()
And the latest 3.2SS that just got tuned. Ambient temps were a wee it lower for this one, hovering around 10C.
That's fabulous! Wow. what cam is that with?
No physical quantity completely explains its own existence |
Wow, that's awesome! Also curious on Cam. That DC44 seems like a great fit.
Instagram @everythingcrafted Day Job - Crafted Wealth www.craftedwealthmanagement.com |
dc44-110
Does that debunk the theory of SSIs being restrictive?
Also, how does a 3.2 out-torque a 3.4 - my simple brain does not compute?
Shirish 1987 Carrera, Granite Green |
What factors helped you decide to do a Lobe Separation Angle of 110 on the 3.2 and 108 on the 3.4? Thanks for educating us!
![]() Cheers
Trumpet length, butterfly placement and injector placement are all factors as well. I would love the budget to fully optimize and test various configurations. Have done limited back to back dyno testing with open velocity stacks vs tea strainers vs typical K+N Watersheild style filter, but would love the time and budget to do more. I love finding what works, and debunking myths like we did with the filter tests on 2 different motors. Cheers
Thanks Jeff - you may have seen my dyno graph floating around on a few threads.
This is a 3.4 with GT3 crank, 45mm ATPower, twin plug, 11.5:1, motec, William Knight (Elgin) cams, Eisenmann 42mm OD SSIs. Thin lines with stacks, thick lines are 993 plenum. The map for the stacks was tidied up after the graph was plotted so some of the ‘waves’ will have been reduced.
Schleprock
This thread is useless, absent of engine pictures.
Kevin L '86 Carrera "Larry" |
The 3.4....
![]() The 3.2SS... ![]() Cheers
That torque curve on the 3.2ss is impressive, especially down low. Can i ask which port sizes you went for? I hear that big ports kill low end torque
72 914-6 GT Conversion 2.7 82 911 SC Coupe 78 SC Targa Hotrod |
Travis, we used the stock small port sizes, just had them cleaned up in the guide area and then the manifolds for the itbs were matched to the ports.
Cheers
Our Dyno Tuning shop, Statified Automotive Controls, asked if they could get their hands back on the 3.4. We obliged. This was the first AEM Infinity they had tuned. Once they tuned the 3.2SS they thought they could coax a bit more power out of the 3.4. And they did....
An additional 16 WHP and 9 lb/ft. Very pleased. Can't wait to see what they do with the 3.8 next week!! ![]() Cheers
Or 39.5 from 78-79/ or the 42.5 from the 3.2? thanks Jeff , great job
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
