Crankcase Studs.
Guys.I need to replace a crankcase stud.Car is 78sc.This is the lower pair that mate to box.Brought one home to measure, and it is 92mm.I used 1978 PET and 1986.Porsche did not make a 92mm (or even close!) stud,according to Parts diagram.
Am I missing something here?
Hardware store. If you need to be real specific, McMaster carr
yeah,I can get generic.I need precision.Thanks
Chain fence eating turbo
It's probably a 95mm stud. A lot of hardware is shorter than the specs. I assume this is so the hardware does not bottom out in a blind hole.
And there is nothing special about Porsche studs other than the headstuds AFAIK. As stated above, McMaster-Carr or your local Fastenal should have them.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
The 3 short ones on the bell housing
999.061.034.02 Bruce |
cylinder/head studs
are the studs interference fit threads at the case?
What is the correct locking compound? |
You don't need locking compound unless removing a stud damaged the case threads. In this application, best to install your favorite case saver insert. Typically these studs stay put when you go to remove the nuts.
The PET stud length is only the exposed length of the stud, not the full length. Rob
Correct. Very confusing until you figure that out. I use Belmetric for all my metric fasteners, they have anything you'll ever need and then some.
