Engine rebuilser's quiz topic
You do multiple leak down tests, but can't get consistent readings of those numbers. Wherein lies the problem? Is it a bent valve? What could you say off the top of your head?
bernie
911heaven
Old 11-28-2019, 04:06 AM
Listen to where the air is leaking.
Old 11-28-2019, 05:26 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Carbon from the spark plug contaminating the exhaust seat.
Try tapping on the exhaust rocker.
Or possibly the cylinder off tdc.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-28-2019, 09:16 AM
Thank you Dannobe and Henry! We've already strrpped it down for a fresh top end job in process. So far it looks like it needed it, so thanks again. Shouldn't be any problem once this is completed.
911heaven
Old 11-29-2019, 11:32 PM
