@reimaginedcoachwerks
a few progress pics from this week.
964 cam tower is ok to use on earlier motors?
apparently so. they were on the car when i bought it. i asked around when i noticed it and the consensus i got from the people i respect was possibly end of the 3.2l engines started getting 964 parts or they were replaced at some point due to possible wear in the past. i never dug any deeper than asking my mentors and getting the above as an answer. sorry i do not have anything more definitive, maybe bruce or henry could shed some light on this question.
Easily Confused
My October-1988 3.2L has the same P/N on the cam/rocker housing.
Scott C. '08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65 |
Try not, Do or Do not
The 964 number is just a casting number. When Porsche transitions from one model to the next they quite often use the newer casting to make parts for previous models.
Generally a 964 cam tower will not fit an earlier engine (cam feed plumbing is different) but we came up with a solution.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
sorry for the delay in my updates.
unfortunately the other pics dialing in the parallelism of the cams where so blurry you cannot read them. |
building oil pressure.
running in the cams.
and a week later after i broke the engine in for drbrian she is off to her new owner!
drbrian has now received his new baby. I am proud to see her tucked away safely in her new garage amongst her new siblings! He certainly has impeccable taste!!!
