smarjoram's Avatar
Damaged rocker - reuse or replace?
Have been sorting out broken head studs and found some damage on a rocker. It must have happened a while back as you cn see a difference in the polished surface of the cam (it's not scored or damaged in any way - just a different colour). Looks like it was maybe a casting defect.
Should I replace it. If so, do I need to worry about how the replacement will bed in? Does it matter if I use a new or 2nd hand part?
Thanks for your help.
'81 SC
stefanmarjoram.com
sketch blog
flickr
Old 05-21-2021, 07:40 AM
Crusty Conservative
silverc4s's Avatar
My vote - replace it. Used one should be fine.
Not an expert, but have rebuilt a few of these.
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 05-21-2021, 07:57 AM
It's a 914 ...
stownsen914's Avatar
That looks like a chip. Granted most anything can be repaired - may not be worth it though.
Old 05-21-2021, 08:02 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Replace it with a similar rocker.
There are a bunch of different rockers in the used market and new. Some are junk.
Shoot for an original rocket of matching configuration.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
It's a 914 ...
Should have the cam lobe assessed too
Old 05-21-2021, 08:03 AM
smarjoram's Avatar
Thanks very much for the advice. Have got a replacement on the way.
'81 SC
stefanmarjoram.com
sketch blog
flickr
Old 05-22-2021, 12:48 PM
BURN-BROS's Avatar
I’ve never seen such a failure! Is that an original piece?
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 05-23-2021, 06:24 PM
Replace, too far gone
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 05-23-2021, 09:36 PM
