Chain fence eating turbo
Ring gap for boost
I'm fairly confident I didn't gap my rings enough the 1st time I rebuilt my engine (3.4 based 3.2) and tore up the Nikasil.
Boost is pretty addicting to me and I live in central Texas where temps get over 100 degrees - I'm leaning on a healthy gap this time.....
What gap would you guys do?
Per Wiseco, they are stating (for boosted race motors) around 0.006" times a 4.000" bore resulting in 0.024" total gap. I have 98mm/3.858" cylinders so should be close to this gap.
Another site is stating around 0.007-0.008" per inch of bore for E85 and high boost. That would be 0.027" to 0.031"
What would you do?
I rather go loose and have a tad more blowby than ever butt ends of the rings!!!
TIA
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 07-12-2021, 10:41 AM
It's a 914 ...
stownsen914's Avatar
I'd assume the piston manufacturer should give you the best info. Make sure they know you're using plated aluminum cylinders.
Old 07-12-2021, 07:45 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Manufacturer should get you close. The important thing to remember with boosted and high RPM engines is that the 2nd ring should have .004"-.008" additional gap.
The theory is that you want gasses trapped under the second ring to escape without pressuring the top ring.
Edit
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-14-2021, 01:42 PM
Henry,
Do you mean 0.004"-0.008" additional gap?
Harold
Old 07-14-2021, 06:15 PM
Originally Posted by HaroldMHedge View Post
Henry,
Harold
Sorry, you are correct .004"-.008"
Henry Schmidt
Ph: 760-728-3062
Old 07-15-2021, 06:26 AM
Thanks y'all, I set them to the high side of heavily boosted motors.
Old 07-18-2021, 11:12 AM
safe's Avatar
Ah, so that is the reason! Thanks!
Magnus
Old 07-21-2021, 02:51 AM
Call 911
dkirk's Avatar
What Henry states is also good advice for naturally aspirated engines. A slightly increased end gap on the second compression ring reduces oil consumption.
Dave Kirk
My Porsche restoreth my soul.
Old 07-31-2021, 10:18 AM
