Benefits of full ignition control is to pinpoint the best timing for the full RPM range. That number is dynamic and unique to the fuel choice, ignition control vs actual spark event when ignition control latency isn't calibrated, RPM, and the engine package as a whole. The peak timing number is in the mid 20's in this case. Michael
Standard Competition Motors, Berkeley Heights, NJ | Maxxecu engine management and Plex tuning calibration specialist and supplier | chassis dyno tuning and calibration consultations http://www.instagram.com/standard_competition_motors |
PCA Member since 1988
Mike, thank you for your reply.
I know that the timing is dynamic and depends on multiple factors, but I was looking for a comparison of the timing at a defined condition to compare to the timing typical of a conventional twin plug piston and chamber at the same condition. If your engine is in the mid-20’s with the Apgar piston, then that puts it in the range of the timing of the twin-plug ignition with a conventional twin-plug piston dome. Is that about right? Or does it require several degrees less advance? Maybe I am not asking the question in the best way, but I am looking for some method of comparison, without having the same engine, but with conventional twin plug pistons, to run on the dyno for a direct comparison. I think that comparing timing is the next best method.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Pete, When the hardware allows I do individual cylinder trims as needed so that is why I was ambiguous and mentioned that its dynamic, both this motor I posted about and the comparison motor were timed this way. Also I consider the tune information proprietary to the paying customer. To give some numeric info though, it has a mean delta of 3-4 degrees less than a full dome piston in a pretty aggressive build on the same regional E10 pump gas.
Standard Competition Motors, Berkeley Heights, NJ | Maxxecu engine management and Plex tuning calibration specialist and supplier | chassis dyno tuning and calibration consultations http://www.instagram.com/standard_competition_motors Last edited by Rivet; 10-23-2025 at 07:11 AM.. Reason: Poor spelling |
Mile, thanks. That is what I was looking for.
With a nominal combustion chamber of 90cc and deck height of 1mm, the compression ratio would be 10.26:1. Assume this is recommened for engines with twin plugged heads also.
Always learning. www.aircooledporsches.com.au |
