It will get to 330..
I'm not picking my nose..I'm porting my upper intake manifold.
Old 08-21-2024, 01:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
All numbers at the crank
Torque is, 267 lb/ft 3950 rpm and 272 lb/ft @4425 rpm and 270 lb/ft @4100 rpm and 267 lb/ft @5325 rpm, Thats 5lb/ft of variation in TQ over 1325 rpm
Also, 221 lb/ft @2100 rpm
More to come
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 08-21-2024, 01:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
Still have sets avail.
Who wants to make some power
Old 10-13-2024, 02:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
Axel84's Avatar
You got pistons for the 2.0S 1969? And 3.4
My worst fear is that when I die, my wife will sell my cars for what I told her I paid for them
Old 10-13-2024, 12:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
The 2.0 no
But we have sets for the 3.4 avail
Old 10-29-2024, 06:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
More to come
Ian
78.5-80 lb-ft torque per liter is pretty solid!
Sent from my Pixel 7 using Tapatalk
Old 10-29-2024, 10:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
I'm doing some planning around rebuilding my 2.7, would these new pistons be a good idea?
Old 10-29-2024, 12:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
Is there any value in using this design for a turbo engine build?
My 3.0sc engine is to be rebuilt using 964 crank and rods, and aiming for around 8.5;1....
Not sure if James can have a set custom made with correct pin heights etc?
Always learning.
www.aircooledporsches.com.au
Old 10-29-2024, 10:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
Mike , this piston is designed to take advantage of the scavenge effect of valve overlap.
Hence the trough cut in the center of the piston.
With a turbo the best bet is the soft dome and sometimes a hollow in the center.
Forced induction makes up for the scavenge effect.
For all other NA 911 engines this piston is very effective .
Just my thoughts
Old 10-30-2024, 05:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
Not currently making new sets. We have to move the current stock of 3.2-3.4 stuff on the shelf.
Old 11-04-2024, 05:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
Moved a few sets more dyno numbers soon from pelican members?
Old 12-17-2024, 05:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
Back up top
Old 02-22-2025, 08:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
Another set shipped waiting for a few dyno results
Old 04-09-2025, 02:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
Monthly humpback up top
Old 05-16-2025, 05:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
I've been wanting to try these but until someone actually posts their results from using them, I'll sit on the fence.
Surely someone must be running an engine with these by now? Or is the "absence of feedback", the feedback in itself?
no offence intended to the seller.
Always learning.
Old 06-12-2025, 04:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
Jeff Alton's Avatar
Mike, I am sitting on my 74.4 stroke 98mm set waiting for a build where the client wants to turn a 3.2 into a 3.4. We have been doing smaller and largerdisplacement and watercooled mostly lately. But I am looking forward to buiilding a motor with them.
Cheers
www.turn3autosport.com
Old 06-18-2025, 07:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #136 (permalink)
8 sets left in stock
Old 10-16-2025, 03:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #137 (permalink)
PCA Member since 1988
What size pistons are in stock?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-16-2025, 05:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #138 (permalink)
Hello guys,
I just wanted to share a dyno chart of a motor that Will Pyle assembled for one of our customers last year, numbers are to the wheels.
It is a 3.4 liter 3.2 with KR75 cams, Apgar pistons, SSI and Dansk muffler, twin plug ECU controlled, PMO throttle bodies. I supplied the Maxxecu engine management system and install support to Will and calibrated it on my dyno. I found the pistons to make for a very efficient combustion chamber requiring less ignition timing to reach MBT.
Two thumbs up from me.
Standard Competition Motors, Berkeley Heights, NJ | Maxxecu engine management and Plex tuning calibration specialist and supplier | chassis dyno tuning and calibration consultations
http://www.instagram.com/standard_competition_motors
Old 10-21-2025, 08:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #139 (permalink)
What full-throttle, full-advance timing did you find for max torque?
Old 10-21-2025, 11:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #140 (permalink)
