PCA Member since 1988
I would like to see finer thread on the adjusters. That would make counting turns to set valave clearance easier and more precise. I know that ain’t gonna happen though.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-20-2023, 03:36 PM
Try not, Do or Do not
Henry Schmidt's Avatar
I'm confused. I've never had a problem with the original design.
Of course there are times when the adjuster was over-tightened rendering it unusable.
When we rebuild our rocker, we throw away damaged adjuster and clean the threads in the rocker with a forming tap.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-20-2023, 04:39 PM
Originally Posted by safe View Post
You need one hand to keep the adjuster from over tighten and one hand too tighten the lock nut. Slot, allen, torx on the end of the adjuster is not an issue.
Why a torx slot adjuster was developed? Someone thought there was a market I guess, Plenty of people with Porsches and too much cash to spend...
Joes picture is from someone two-handing the lock nut (doing it wrong), stupid people (not blaming Joe) do stupid things, no fancy parts will fix that!
You must have really strong wrists…
Old 12-20-2023, 04:49 PM
So its not just me.
I'm utterly confounded by the endless long threads about valve adjustment, backside methods, and the cottage industry that has sprung up making special tools for something that just isn't a problem. In my opinion its one of the easiest things to do on my car.
Or maybe I'm just grumpy and need to go open my wastegate a few times today
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 12-29-2023, 06:48 AM
I think this is a great idea. I have a set of box wrenches with one end that has a ball shaped or rounded off end that makes it useful when at a slight angle. I find that the flat head screwdriver moves out of place WAY too easily. I don't adjust valves for my day job so anything that makes this easier and more controllable is a good idea. I guess the big question is who's got an incentive to fabricate this?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 01-05-2024, 08:07 AM
Originally Posted by flightlead404 View Post
So its not just me.
So sorry for asking voicing my opinion. I will refrain in the future.
Old 01-05-2024, 11:10 AM
No, please bring the questions you have. This is a forum where guys hang out and so don't be surprised if you get a little push-back. I've been doing this for 40 years and I still get push-back for some of my ideas.
Henry Schmidt
Ph: 760-728-3062
Old 01-05-2024, 11:19 AM
Ditto what Henry said. I've been doing online car discussions for 25 years, and I know it's difficult to understand the context of what someone else wrote when you don't have face-to-face feedback. Sometimes it pays to challenge the accepted wisdom, and new guys bring a fresh perspective that the old guys sometimes dismiss too quickly.
Old 01-05-2024, 12:11 PM
Thank you, Henry, and PeteZ. I too have been involved in chat rooms forever since the beginning of the internet. I cannot remember the format, but there was a rudimentary version which was only strings with text. I recollect that they were called “Message Boards.”
I had been called out on a board for referring that an RSR Rocker Shaft Seals, now (911-099-103-52), that go into the two groves of the rocker shafts. It was 1986 when I rebuilt my 1972 911T engine. They serve as RCSRT. The other person in the chat, string, insisted it was not an O-Ring because it did not have a round cross-section. Yes, a Proper O-Ring has a Toric Cross-Section, BUT can have unintended “Wipers” or ribs on the outside and inside radii. As I said, these unintended ribs are caused in the molding process. Federal NAS and MS specs have allowed and document the ribs not to exceed .005” height and .003” width. Even Wikipedia shows this, just on the fact it is Wikipedia makes it true. HAH! The early Porsche seals were die cut with square edges. I know it was not the exact geometric term as defined “O-Ring,” but Rectangular Cross Section Round Thingy’s works, which now and forever be termed by the acronym (RCSRT’s). I now Officially own the name, and the term is a pending copy write. Also in German, with respect to our beloved founder, “Rechteckiger Querschnitt Rundes Ding" (RQRD’s).
RCSRT© pending
RQRD© pending
I was using the term O-Ring loosely because it was the easiest term to use since it was a seal that went around a shaft in the two grooves. The were never designed for a seal. So, some mechanic on some team was dealing with an issue with an engine that leaked at the possible 24 junctions and came up with the idea, Now Officially a RCSRT. He may have cut the center hole and used the sharp edge of the Cam Case where the Rocker Shaft resides to shear the seal round. That is the exact thing we were discussing and that was exactly the point I was making on the Message Board. The seals were little known at the time, and I do not believe that Porsche sold them.
I write this off as another nitwit who is the self-appointed expert because of what they thought and without the complete knowledge conversational English, nor conversational colloquialism usage.
Now back to my original point of the thread. Of all the Porsche engines (911T, 911SC, 914 (2), and VW engines (10), and fifty aircraft engines that I have worked on since the mid 70’s, it has always been tedious, but not hard to adjust the valve on the engines. I use a dial indicator and can read or interpolate .00025”. Yes, ¼ thousandth of an inch. A ¼ of the space of the .001” increment lines are repeatable. Feeler gages are ok but are subject to variances with the user’s feel. I just make the extra effort to appease myself. Or prove my settings to myself.
Sorry for the bragging below, but it tells a bit of my qualifications.
Yes, I have a valid A&P License, am a Mechanical Engineer, a Senior Staff Design Engineer, Engineering Design Checker, worked on 3 Billion Dollar Satellites, scud Missiles, and Torpedo’s.
Henry and Pete, below is not about you. You two have my respect.
So please refrain from telling me and others that I am doing it wrong and that I am Stupid.
“Joes picture is from someone two-handing the lock nut (doing it wrong), stupid people (not blaming Joe) do stupid things, no fancy parts will fix that!”
Old 01-07-2024, 09:54 AM
